20 Most Recent
Life Science Bionet Cardiotouch 3000 12 Channel Ecg With Color Lcd Questions & Answers
Ekg machine states left leg fail, but none of the
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Low battery
When your dealing with a low battery message you can do many things like the following:
1- Replace the battery.
2- Check the voltage of the battery with a multimeter.
3- Disconnect the unit from the AC source and check if the unit continue functioning without the AC source.
