20 Most Recent
Yamaha CDC-585 5-Disc CD Changer Questions & Answers
Can i fix the tray on Yamaha CDC-585 that will not close?
See if the tray motor drives a belt to move the tray, if so, check if the belt is loose or broken and replace if necessary.
You can find replacement belts in electronic part stores and on internet, you need to measure the diameter of the circle that the belt forms so you'll know what to purchase, but keep in mind that the new belt will be of a slightly smaller diameter than the used one).
Also check the tray homing switches for dirty contacts or physical damage and clean/replace if necessary.
These switches are usually of a touch contact type (something alike relay contacts that are being pressed to make a contact when the tray is in either of the extreme positions - open or closed).
It may as well be something else like tray motor control section, loose wires or connectors, physical damage to any of the tray drive gears or other tray parts, a stuck/obstructed gear... i only described two of the fairly common problems that often cause the tray mechanism to fail or malfunction.
Hope you can fix it...
regards
3rq8 (Triarcuate)
DOOR KEEPS OPENING
Hi. there is a tiny limit switch that regulates the actual CD platform drawer(The part where you lay down the CD). this switch if faulty. it is designed to shut of the load motor when the CD tray is fully inside the unit.
this limit switch must be replaced. this is a job for a qualified Yamaha service tech. contact Yamaha for this repair.
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Cd player stuck
Hi..
It will have to have the coverr taken off and the drawer belt replaced.
Find a stereo repair place.
Skipping yamaha 765
I have a very similar type unit, a Nakamichi CDC-3 that had the same problem. I found this link....
http://repairfaq.ece.drexel.edu/REPAIR/F_cdfaq6.html#CDFAQ_001
I spent about two hours fixing mine. The sled mechanism was binding somehow, causing random skipping. The first 10 minutes was getting it apart and figuring what was wrong, the remainder was spent getting all those tiny parts back in the proper place.
Look up the exact symptom before going at it (probably long skips). Set aside a long slow lazy day with nothing to do. DO NOT drink too much coffee, you will be handling tiny parts that go in tedious locations, so you don't need caffeine jitters adding to your misery. Take your time and be careful. It's well worth it. Mine plays like a new one.
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
