20 Most Recent Craftsman 675 Torque 190cc 21" Briggs Stratton RearBag Push Lawn Mower (CA) () Questions & Answers
I am guessing that this is your ENGINE model number: 126K02-0512-B1
Using this reference:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=126K02-0512-B1&dn=35820003
Check to make sure that the choke item number 97 is not sticking.
Then remove the float bowl nut and float bowl assy. Clean the fuel passages in the base of the carb with carb cleaner including the area where the bowl nut screws into. There is a fixed jet orifice that must be cleaned in the threaded area. Also clean the visible brass tubes in the top of the carb.
Check fuel flow with the bowl removed. You should have a good fuel flow with the float angled down and as you lift it level fuel flow should STOP. If you do not have fuel flow... remove the float pin, drop the float and needle and celan out the hole where the float needle was. Remove the main fuel line and check for fuel flow. Use carb cleaner in the hole where the fuel line connects. If you do not have feul flow from the fuel tank.. check the tank port and look for any kind of in line filter. If you find a filter... check the line before and after the filter for fuel flow. Once you have established fuel flow Reassemble carb
Check the spark.... if you have no spark
First check the thermostat by just disconnecting it. Item 291
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=126K02-0512-B1&dn=35820004
Then retest your spark. If you have spark with the thermostat disconnected the themostat is bad. (Most engines use a low oil level sensor..... this one uses the thermostat)
There is an electrical contact on the throttle plate that is grounded when the throttle is selected to off. Make sure the throttle plate lever moves off of the contact when you advance the throttle. ALSO... there is another ground / contact on the engine brake. Make sure that when the engine brake is released that the brake lever moves away from the ignition grounding contact.
The above are the basics.... If after doing ALL of the above you still have problems with ignition then suspect the ignition components.
Thanks for choosing FixYa,
Kelly
Craftsman 675... | Answered on Nov 13, 2018
hi there.
if you go to this link it might help you get it sorted.
lawn mower cord won retract Craftsman self propelled lawn mower Honda...
Craftsman 675... | Answered on Nov 06, 2017
probably a bent crank shaft or blade is out of balance
Craftsman 675... | Answered on Apr 12, 2016
Check your fuel line you could have a crack in it causing a vacuum problem.
Craftsman 675... | Answered on Apr 11, 2016
Bottom of engine on right side
Craftsman 675... | Answered on Mar 27, 2016
I would take it back to the store and ask for warranty repairs since it is so new. That's ridiculous. If that doesn't work, try Sears Parts on-line or on the phone. They are better than most other manufactures.
Craftsman 675... | Answered on Sep 16, 2015
vibration in a walk behind mower is most always a imbalance in the blade , there lots of things that cause this , from loose blade , to bent blades
remove blade and test with blade balance , there not expensive ive seen them with a sharping stone for less than ten dollars before
pull spark plug before you remove blade 4 safety
Craftsman 675... | Answered on Jul 09, 2015
Does it stay running after you squirt fuel in the carb opening? If yes, then there may be a pin hole leak in the hose going from the fuel tank to the primer bulb and it is adding air to your carb.
Thanks
Craftsman 675... | Answered on May 02, 2015
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Craftsman 675... | Answered on Feb 02, 2015
Drain all the gas out of your fuel tank via fuel line to carburetor. Then remove the bowl under your carburetor, place container under carb first. You will see that you have water in your gas. Just a little would keep your mower from starting and running. GOOD LUCK FRIEND.
Craftsman 675... | Answered on Sep 21, 2014
when does it do it ??? Only when you are driving the mower ??? if its a rear drive mower I would suspect the axle/trans/drive wheels are making the noise.
Craftsman 675... | Answered on Sep 11, 2014
what wrong with it if it wont start check for spark at plug if works try squrting starter flood into carb if tries to start rebuild carberator tecuseh engines are bad about clogged up carb with dirt
Craftsman 675... | Answered on Aug 29, 2014
Oil is entering the combustion chamber some how
Craftsman 675... | Answered on Jul 10, 2014
How long since it ran last? Is it getting spark? Seem like it has good compression?
Craftsman 675... | Answered on Jun 25, 2014
Hi there. It sounds like its getting to much fuel and flooding the carb.
Craftsman 675... | Answered on May 27, 2014
Yoy can try tightening the blade bolt. i know it sounds funny but if the blade bolt is loose (or even alittle loose) the blade balance throws off the engine balance and can cause it to
1 not start
2 make loud clunking noises when trying to start
3 make a real racket if it does start
try flipping the lawn mower over and just tighten the bolt that holds the blade in place.
That should fix your problem.
Please dont forget to rate my answers
Thank you
Craftsman 675... | Answered on Apr 22, 2014
Craftsman 675 Torque 190cc 21" Briggs  Stratton RearBag Push Lawn Mower (CA) () Logo
Popular Tags
104 questions posted
Top Craftsman Garden Experts
Dennis Key
Dennis Key
john h
Sheldon Dedek
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
mower making sound like blade hitting
  • Garden
