20 Most Recent Yamaha GX-70 CD Shelf System Questions & Answers
hi, ya, someimes the POT i.e the volume controller variable resistor loses its contacts with the carbon strip. tru using some switch cleaning solution( NoN Acidic) to clean the POT,let me know
Yamaha GX-70 CD... | Answered on Mar 19, 2014
Not sure what you want here, there is no setup, if it malfunctions you have damaged parts in the changer.
Yamaha GX-70 CD... | Answered on Dec 21, 2009
hi, you will need some cables for this job. to connect ur GX to the comp will take a stereo RC to EP cable, the RC connectors will go to the line out of ur GX and the EP will go to the line in of the comp sound card.. let me know
Yamaha GX-70 CD... | Answered on Feb 19, 2008
hi, ya if u know the exact model no. of the remote you can buy a spare one from the manufacturer or any dealer, try searching it on the internet first.
Yamaha GX-70 CD... | Answered on Jan 03, 2008
Remove the short that is causing the protection to engage, then power cycle, assuming it's a short circuit protection. If it's going in to thermal protection, then shut the receiver off and let it cool. If all speaker wires are disconnected and the unit is cool to the touch but still appears to be in protection mode, likely one of the output transistors has failed an will need to be diagnosed and replaced. Don't neglect to check the ESR of the electrolytic capacitors if you find a failed device internally.
Yamaha Audio... | Answered on Jan 14, 2021
I have seen several things that can cause this. One is a capacitor that holds the memory in the cpu. Another is a voltage regulator and then there are failures in the final amplifier transistors
Yamaha Audio... | Answered on Nov 24, 2020
Unplug all your speakers and components. Then turn on, if it still locks up you have one of maybe 5 safety features hooked up that are built in to stop your amp from blowing. You will need to replace board or have some cool tech dude desolder and isolate . Look for wiring diagram for safety shut down system. Sorry but if it doesn't do it after you disconnect every thing then check each speaker with ohm meter to read factory specs.
Yamaha Audio... | Answered on Nov 10, 2020
Yes but only limited functions!
like Volume and on and off.
Yamaha Audio... | Answered on Nov 08, 2020
I bought a damaged rx v1 to repair it and I measured everything and according to the voltages it is ok but and repair it
Yamaha Audio... | Answered on Jul 20, 2020
It's in protection mode. Disconnect all speakers and hold the Tone and Straight buttons while hitting the power button. Hold all buttons down for 3 to 5 seconds. This will turn off protection mode. Now power down then back on. If you haven't damaged anything it should work fine. Make sure all speaker connections are good. Always power down the unit before making any speaker or other connections.
Yamaha Audio... | Answered on May 12, 2020
Just connect the VX7 to the 5730 using an RCA Y cable. It should help
Yamaha Audio... | Answered on Apr 25, 2020
Should have very small hole, insert straightened paper clip to eject. Alternately accelerate it at 32bft per sec sqd
Yamaha Audio... | Answered on Mar 24, 2020
Yamaha GX-70 CD Shelf System Logo
Popular Tags
7 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
remote control
  • Audio Players & Recorders
