20 Most Recent Yamaha HTR-5560 Receiver Questions & Answers
2answers
Cant get to set up menu on yamaha htr-5560 without remote
That is a real problem, the remote is vital to the settup. Go to www.ebay.com Type: make and model you may get lucky, this is one of the few sites that sells old and the new products that you normally don't see.
10/7/2022 8:11:40 PM • Yamaha HTR-5560... • Answered on Oct 07, 2022
Do Yamaha HTR-5560 receivers have a ground wire plug in?
If your receiver has a metal cabinet you can use any of the screws that hold the cabinet on.
10/8/2014 3:15:40 AM • Yamaha HTR-5560... • Answered on Oct 08, 2014
Sound from only 1 front speaker
Check you speaker wire connections and make sure they are properly connected and make sure the wires are not flipped +/-
12/16/2013 3:33:21 PM • Yamaha HTR-5560... • Answered on Dec 16, 2013
2answers
Yamaha av receiver rx-359
go to best buy and buy a new recever
12/13/2013 10:10:50 AM • Yamaha HTR-5560... • Answered on Dec 13, 2013
What year was Yamaha Htr-5560 made and what year
Hi, Look under and on the back of the unit. You may find where it was made and the year. if not the serial # may help you too. Last 4 digits.
7/30/2011 3:56:40 AM • Yamaha HTR-5560... • Answered on Jul 30, 2011
Everything was working fine, then the sound quit
please try to find new firmware for this model, I guess it is HDMI version compilable problem. maybe after update firmware could fix your problem
3/18/2011 4:37:49 PM • Yamaha HTR-5560... • Answered on Mar 18, 2011
Yamaha 5560 no sound from front left and right
hi,
just check by fault switched of the frond speakers. power on the receiver play some thing listen sound is coming from the other speaker except frond. press the speaker A button in frond of the receiver. listen is it become on. if not got to the menu of ur receiver surf for speaker configuration . find out the whether the frond speaker is off. if it off turn it on.
12/15/2010 7:01:33 PM • Yamaha HTR-5560... • Answered on Dec 15, 2010
I've had the same
Sounds like the unit is set to shutdown if it detects a short in the amplifier. The problem can be within the supply but it is most likely in the amp section of the unit. Transistors will go out over time and need to be replaced. Find a local repair shop and have them estimate the repair for you. the cost on something like this can be in the 70.00 range depending on shop rates in your area and the extent of the problem.
5/4/2010 5:56:59 PM • Yamaha HTR-5560... • Answered on May 04, 2010
Just makes a clicking sound will not turn on
probably in protect! will need the amp tested as
it may have a channel out!
4/11/2010 3:41:20 AM • Yamaha HTR-5560... • Answered on Apr 11, 2010
Suddenly, I can only hear the sound faintly, even
Have you checked the MUTE function?
NEVER turn the volume up more than half-way for any sound problem. Otherwise, if you suddenly find the switch that's out of position you could blow your speakers.
What converter?
What channels, what source(s)?
2/27/2010 11:08:30 PM • Yamaha HTR-5560... • Answered on Feb 27, 2010
Yamaha receiver will not turn on. just a clicking
Your unit have had detected a fault and enter the protect mode. To determined, what exactly wrong with it, you will have to take it to Yamaha authorized repair facility.
12/26/2009 6:25:22 PM • Yamaha HTR-5560... • Answered on Dec 26, 2009
Volume on my yamaha htr-5560 is broken. Doesn't
Only way to fix this problem, is to replace volume encoder. Ease repair and inexpensive part.
11/5/2009 9:30:35 PM • Yamaha HTR-5560... • Answered on Nov 05, 2009
Yamaha HTR-5560 Receiver Logo
45 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
yamaha 5560 no sound from front left
  • Audio Players & Recorders
