20 Most Recent Yamaha RX-V640 6.1 Channels Receiver Questions & Answers
4answers
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
6/29/2012 2:42:26 PM • Yamaha RX-V640... • Answered on Jun 29, 2012
0answers
0answers
My RX V640 is 5 years old..no problems...no
theb best way to do this is to connect the DVR to the vhs unit and the vhs unit to the tv using red white and yellow for both connections. usually composite video 1,2,3 or 4. DO NOT involve the AVR at all, as it will cause your video and audio to be out of sync.The video will not be as sharp, until you play it threw an up-converting dvd or AVR.
8/21/2009 9:10:44 PM • Yamaha RX-V640... • Answered on Aug 21, 2009
How to reset yamaha htr -3066
With unit in standby, hold down the Tone control button and the Info button at the same time. While they are being pressed push the power button. The unit will turn on in service mode. Hit the BD button repeatedly until you see S3. This is the factory reset. Press the CD button repeatedly until it says Preset Reserved. Press the power key and the unit will be reset to original factory specs. Good luck to you.
11/2/2022 1:29:19 AM • Yamaha Audio... • Answered on Nov 02, 2022
Yamaha Receiver. HDMI light is on.
Are you drunk? Edited out all the nonsense and corrected dreadful spelling. https://www.google.com/search?q=Hdmi+light+is+on+yamaha+receiver ..
10/30/2022 5:07:09 PM • Yamaha Audio... • Answered on Oct 30, 2022
2answers
How do I reset my yamaha receiver htr-5450, back to the original factory settings
1. To restore your amp to the Factory original standards: Please press one of the component selector buttons other than AMP(TUNER). Press both VOLUME buttons (u/d) at the same time for about four seconds. The indicator flashes twice. Enter the code number "9990". Make sure that the indicator flashes twice. 2, To return to the factory-set codes in each mode: Press one of the component selector buttons which corresponds to the component to be returned to the factory-set code. Press both VOLUME buttons (u/d) at the same time for about four seconds. The indicator flashes twice. Enter the code number "0000". Make sure that the indicator flashes twice. The following codes are factory set. Component selector button Code TV 0101 CBL/SAT 0006 VCR 0002 DVD/LD 0008 CD 0005 TAPE/MD 0024 It is recommended that you should write all the code numbers you have set on the table above.
10/17/2022 4:56:06 PM • Yamaha Audio... • Answered on Oct 17, 2022
Use front panel to access menu have no remote yamaha rx-v463
Hi, Please search for your remote model on Amazon and Ebay. You should be able to find and purchase a replacement. Thank you.
10/5/2022 8:10:04 PM • Yamaha Audio... • Answered on Oct 05, 2022
2answers
When I turn on my Yamaha RX-V657 without the speaker wire connected, it only stays on for one second and then turns off. No error is displayed on the screen. Is this normal?
you forgot to see the AVR works prefectly using speakers 8,6 or 4 Ohms Z, selected to right ohms the switch. does it? if yes he below is moot, why do that. it there is sound source running, and loud and you have no speakers there, that can damage some amps. so don't do that, some AVR have no error code, protection lamp just relay clicks your AVR is really old a sea of RCA jacks on the rear. there is no need to run any amp ever, lacking a set of speakers. 7.1, does have rules here, no sure me miniumum rules. may be 2 are required min. (the selected set A or B) what I do is read the manual first . found it googled in 1second flat. page 88 The protection circuitry has been activated. Make sure all speaker wire connections on this unit and on all speakers are secure and that the wire for each connection does not touch anything other than its respective connection Check that the impedance selector setting is correct ok I have repaired amps (AVR and others back to 1960s) the protects circuits trip 1 or 3 ways or both (tech facts)
  1. over currant the PA (power amps at speaker jacks)
  2. or imbalanced driver transistor pair (push pull or class A)
  3. or overvoltages there. now.
so if it has way 3, and he source is full volume and heavy metal band then it trips. no speakers due to output is way too high. an amp that can do 1000w peak can do 90v peak to a speaker. yours is 95watts RMS each , peak is not stated. nor is protects stated in absolute terms. free https://www.manualslib.com/manual/340487/Yamaha-Rx-V657.html?page=18#manual answer 1,. turn off all sources and volume down to run no speakers. also it told you power off to connect. speakers. when you do not power on the surge in the PC can be huge so it tells not to do that.
10/2/2022 8:18:35 AM • Yamaha Audio... • Answered on Oct 02, 2022
How do I reset the protection circuitry on Yamaha RX-A820?
press and hold the 'tone control' and 'info' buttons and press power. This will release the protect. The first thing that show on the display will be the protect code to tell you why it shut down. If it turns right back off, then you most likely have a short in the amp that will need to be repaired.
9/29/2022 2:52:20 PM • Yamaha Audio... • Answered on Sep 29, 2022
What does error code 0010 mean on Yamaha av receiver Rx-v773
- Firmware update doesn't start or doesn't complete ? Receiver doesn't power up after the update. ? Error message appeared when confirming the firmware version. Recovery method using USB method: 1. Unplug the AC power cable from wall outlet. 2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel. 3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again. " USB UPDATE " will appear on the front display. Then, release the INFO key. 4. The update will start automatically. 5. When " UPDATE SUCCESS " appears on the display, firmware update is completed. Power off the receiver and remove the USB thumb drive. 6. Confirm updated firmware version. - Error message appeared during the update Cause: For some reason, the receiver can't read the firmware data. Method: For your solution, check the following [Update through Internet] ? Check Internet connection. Check if the Internet connection is working by playing an Internet radio station. (See owner's manual for details) [Update by USB thumb drive] ? USB thumb drive is connected properly to the receiver. ? USB thumb drive is not password protected. (AV receiver cannot read data from a security protected USB thumb drive) ? Make sure the USB thumb drive is inserted before the receiver is powered on for the update. ? The firmware data is stored in the root directory of the USB thumb drive. ? There is no other data except the firmware data in the USB thumb drive. ? No folders are created in the USB thumb drive. Else, retry the update by USB using another USB thumb drive.
8/31/2022 4:49:55 PM • Yamaha Audio... • Answered on Aug 31, 2022
How many glass fuses in a yamaha av receiver HTR 6030 AVR
USA or not USA.? countries have laws on power. Our manual 6030 shows not one fuse on the outside at all so they are some inside (fuses) glass or not glass does not mater what matter is blow fuses off all kinds, and present inside. if it is dead the AVR is it. not told i read your service manual, and there are 2 fuses. fuse-undefined-undefined-0_0.jpg 10amp 125v , USA spec AVR
8/29/2022 11:10:12 AM • Yamaha Audio... • Answered on Aug 29, 2022
2answers
How to reset protection mode on yamaha A-S801 reciever.
Repair the power stage and it will then reset.
8/21/2022 10:35:16 AM • Yamaha Audio... • Answered on Aug 21, 2022
Yamaha RX-V640 6.1 Channels Receiver Logo
11 questions posted
Top Yamaha Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
subwoofer
  • Audio Players & Recorders
