20 Most Recent Yamaha RX-V450 Receiver Questions & Answers
Good afternoon. I'm from Russia)) My AV amplifier
This should get you started... https://www.hifiengine.com/hfe_downloads/index.php?yamaha/yamaha_rx-v550_450_htr-5750_5740_dsp-ax450_service_full.pdf You'll need to register but it is free to do so. Good luck! Login HiFi Engine
9/27/2017 9:23:38 PM • Yamaha RX-V450... • Answered on Sep 27, 2017
0answers
4answers
Doesn't power up
Hallo,my name is Peppe and I am an italian technician (Naples). My english language is not perfect but I try to explain how repair the receiver because the mine have the same problem (don't power on after 4 years of regular use ).
The bad component is the capacitor C405 (22nf 630 v )on the relay power board,the same board where are the two socket for the ac outlet.
I hope that my solution help all the persons wich have this problem on this very beatiful amplifier Yamaha RX-V450.
5/6/2013 5:52:31 PM • Yamaha RX-V450... • Answered on May 06, 2013
Amp. doesn't turn on
22nf 630dc/300ac capacitor inside back left board, i found mine on top of this board, a magnifine glass will help to check the writing on capacitor, replaced mine, works as new, g.knight. uk. ( rs components.)
3/15/2013 9:24:10 PM • Yamaha RX-V450... • Answered on Mar 15, 2013
Open Yamaha RX-V 550 remote control
Remove the small screw in the battery compartment then put the long edge of a kitchen knife in the groove & twist. The case will snap open at that point then work your way around until it parts. Clean the contacts inside with Isopropyl alcohol & that should solve your problem.
3/5/2013 7:42:29 PM • Yamaha RX-V450... • Answered on Mar 05, 2013
0answers
My Yamaha RX-V450 cannot power on
Where to find in penang yamaha model RX-V450 capacitor, pls help me because I try so many place but i can't. would you pls help me guy's.......Thanks a lot......Pls mail me at [email protected].
8/29/2011 5:44:05 AM • Yamaha RX-V450... • Answered on Aug 29, 2011
RECVER IS ON SPEAKERS ARE HOOKED UP RIGHT BUT NO
Maybe if you SET it up right you might not need to REset it.
Find the manual and carefully evaluate every indicator on the face to make sure you understand what they mean and how they might affect operations. Look for Speakers NOT enabled, Muting ON, a Tape or other input inadvertantly selected. If you fail to find the errant setting, treat it like a new install and set it up all over again according to the manual.
Register and download it manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V450-Receivers-manual/id/319ci970/t/2/
5/15/2011 6:58:22 PM • Yamaha RX-V450... • Answered on May 15, 2011
0answers
Hi, I have a Yamaha rx-v450 amp that won't
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
5/11/2011 5:41:44 AM • Yamaha RX-V450... • Answered on May 11, 2011
0answers
How can I get hold of a new remote for a yamaha rx
The model is RAV250 (roiginal) or RAV254 (sub)
Read this first:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12987331024191
Searched eBay, found a couple RAV254's for $35 and $43 ...
"rx v450 remote" check the 'include description' box
or ...
$54
http://remotes.com/remotes/servlet/rs?&o=c&o=c&a=Search&uid=0&m=rx+v450&uuid=A12987330771381
2/26/2011 3:16:37 PM • Yamaha RX-V450... • Answered on Feb 26, 2011
Yamaha RX-V450 Receiver Logo
24 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
good afternoon from russia av amplifier
  • Audio Players & Recorders
