20 Most Recent
Robotoolz 5Beam Laser Level Plumb Square Laser Vector 5e Questions & Answers
The self leveling does not
hi chapelhillco. Remove the batteries and clean the contacts with the eraser end of a common pencil. Then clean the contacts on the batteries and reinsert them. This may solve the problem.
Joe
Thanks for choosing Fixya!
I have a robotoolz laser level that I cant get to turn on. I have replaced the batteries, but the laser wont turn on and it wont swivel either. Any suggestions?
If you've replaced the batteries in your Robotoolz laser level but it still won't turn on and the swivel mechanism isn't functioning, there could be a few potential issues causing the problem. Here are some suggestions to troubleshoot the issue:
1. **Battery Polarity:** Double-check that you've inserted the batteries with the correct polarity (+ and -) as indicated on the device. Sometimes, incorrect battery placement can prevent the device from turning on.
2. **Battery Contacts:** Ensure that the battery contacts are clean and free from corrosion. Use a clean cloth or a cotton swab to clean the contacts in the battery compartment.
3. **Battery Compartment Door:** Make sure the battery compartment door is securely closed and latched. Some devices have safety switches that prevent operation when the door is not properly closed.
4. **Reset:** Some laser levels have a reset button or procedure. Check the user manual for your specific model to see if there's a reset function you can try.
5. **Calibration:** Some laser levels require calibration before they can operate. Refer to the user manual to see if your laser level requires calibration and follow the provided instructions.
6. **Electrical Issues:** If the laser level was exposed to moisture or extreme conditions, it's possible that internal electrical components might have been damaged. In such cases, professional repair might be necessary.
7. **Mechanical Issues:** If the swivel mechanism isn't functioning, it could indicate a mechanical issue. Check for any obstructions or debris that might be preventing the swivel movement.
8. **Professional Inspection:** If you've tried the above steps and the laser level still won't turn on or function properly, it might be best to seek professional assistance. There could be internal components that need repair or replacement.
9. **Manufacturer Support:** Contact the manufacturer's customer support for guidance. They might be able to provide specific troubleshooting steps or recommend a repair service.
Keep in mind that laser levels are precision instruments, and improper handling or disassembly could lead to further damage. If you're not comfortable troubleshooting or repairing the laser level yourself, it's best to seek professional help to avoid causing more harm to the device.
8/20/2023 2:27:47 PM •
Robotoolz...
Answered
on Aug 20, 2023
RoboToolz RT-A7200-1 remote has a broken battery 9 volt terminal. Where can I send it for repair?
Normal repair of a 9-volt terminal is to salvage the top of a dead 9-volt battery. Do not use a good 9-volt as they are prone to dangerous expansion if shorted. Take the salvaged battery top and add short red and black leads with a soldering gun/pencil. Use rosin core solder only, not acid core or solid. Replace the damaged terminal using above by connecting the short leads to the original terminals or circuit board traces.
8/15/2019 2:10:26 AM •
Robotoolz...
Answered
on Aug 15, 2019
