20 Most Recent
Digimate DGL26 Television Questions & Answers
I AM UNABLE TO FIND THE REMOTE CONTROL CODE FOR PROGRAMMING DIGIM
This is a very common problem often without a solution.
I'd recommend you check your signal provider's website since they will have an updated code chart but there may never be a code for your brand
available in their or every other remote.
Also, some store or off- brands are not widely enough sold to encourage remote providers to worry about them.
No picture
If you TV is a LCD one, it seems to me that this problem is related with the inverter circuitry which supplies high voltage to the LCD. The presense of sound means that the main power supply is OK. To repair this fault you must look for help of someone qualified to do this particular repair. I hope my aswer will be of help for you.
What other cables nbesides the dvi cable do i need
An AUDIO cable to the TV PC AUDIO INPUT PORT (see Green mini phone jack on the back of the TV for PC AUDIO) another end of the mini stereo phone plug will go into the PC AUDIO LINE OUT (Green miniphone jack).
Polaroid LCD tv - model TLX-04244 Shuts itself off...
The
solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the
symptoms of a dying or defective power
supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to
[email protected]
Lines while watching TV
Lines = bad circuitry. Could be a microchip. Could be a bad power supply to the microchip. Only a tech could look and tell.
DIGIMATE DGL26
Yes ofcourse. Just check the specs marked on them.. You can get them at any local electric store..
