20 Most Recent
Digimate DGL20 Television Questions & Answers
My digimate doesnt have any color??
1. Press MENU, select MISC and press ENTER
Then select Factory Reset.
It is a colour set. If that does not correct it there is a fault on the main board and it will have to be replaced.
Digimate TV DGL20 REMOTE CONTROL
Use just about any remote and use the code for a Protron TV.
1) 0178
2) 0466
3) 0052
4) 0003
First one worked for my digimate 20"
Can you tell me what store can I buy a universal
Any store will have a universal remote for your model, but for yours id recommend a Philips universal. Or you can try to get the original using this link.
http://www.remotes.com/store/digimate/dgl20.html
NO SOUND..SPEAKERS ARE GOOD, NOT
Hello. Go into the menu using the remote. you will be looking for audio. Once in there you will probably see that someone turned off the internal speakers.
Cable?
since the DGL20 uses a PAL connector, you will need an adapter plug from PAL male-to-RF male (75 Ohm) connector. You can also try a RCA male to RF male (75 Ohm)
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
Need new remote
Use just about any uni-remote and use the code for a Protron TV. Try in the following order...
1) 0178
2) 0466
3) 0052
4) 0003
First one worked for my digimate 20" Good Luck !
