20 Most Recent Yamaha YST-SW150 Speaker Questions & Answers
4answers
I have a Yamaha sub woofer model NX-SW150 that was
i am wanting to know the answer to the exact same question. did you ever find the answer?
5/17/2015 3:43:30 PM • Yamaha YST-SW150... • Answered on May 17, 2015
I have a YST-SW150 speaker that turns it self off
I just fixed one of these with the same symptom.In between the power supply board and the amplifier board are a number of rather fine interconnect wires. One of these is the shutdown/startup control line for the auto on/off function. In my case the wire had been pinched where they are cable tied together. Causeing the power supply to think there was no music input and should shut down.rejoing the broken wire rectified the problem.In my case more than one wire had been damaged.the shut down line is labled SO on the amplifier board connector.7_19_2012_1_10_37_pm.jpg
7/19/2012 1:12:51 PM • Yamaha YST-SW150... • Answered on Jul 19, 2012
0answers
2answers
When i turn the speaker on,it shuts itself
Try turning it on and see if it shuts itself off, if so it is probably confused. I would put it in a dark closet for a week or so to teach it a lesson, then see what it does. Or you could unhook the speakers and see if it works fine, maybe your speaker wires are touching each other and grounding out something.
8/10/2010 4:30:06 AM • Yamaha YST-SW150... • Answered on Aug 10, 2010
Yamaha YST-SW150 Subwoofer
hi, is it a humming noise ??? check if the connector is plugged in properly,check the earthing, if its a three pin mains plug, if its a two pin, then the CPU SMPShave a proper eathing. let me know
1/12/2008 1:57:36 PM • Yamaha YST-SW150... • Answered on Jan 12, 2008
Why does my Yamaha HTR-6130 power down after 3 seconds?
I expect there is either a power supply issue or one of the amplifiers has failed causing over current to turn it off as a protection to the power supply.
4/20/2024 6:23:32 AM • Yamaha Audio... • Answered on Apr 20, 2024
Can I connect my computer subwoofer to my Yamaha A/V receiver
Yes if it has a suitable speaker connection available and is nominally 8 ohms impedance Speaker and AV.
4/15/2024 11:25:42 PM • Yamaha Audio... • Answered on Apr 15, 2024
Yamaha M-60 Power Amplifier distortion and sound goes off sometimes
Being from 1985 or there abouts, it probably needs some TLC at a Yamaha service centre. May need new capacitors and resolder dry joints for age related issues.
4/1/2024 7:26:20 AM • Yamaha Audio... • Answered on Apr 01, 2024
Jerky sound in one channel Yamaha M-60 Power Amplifier
WD-40 ... Very dangerous as it not only flammable when wet but is bad for electrical contacts as it leaves a residue behind that does not conduct electricity very well. Check speaker connections first.
4/1/2024 7:22:45 AM • Yamaha Audio... • Answered on Apr 01, 2024
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool. the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny). ampli r027-w2gpcyn2rttv51s5zcrlhnl2-d-0.png
3/5/2024 10:05:15 PM • Yamaha Audio... • Answered on Mar 05, 2024
RX-V6A - Zone 2 Speakers do not give sound
Follow the procedure as given in following link. RX-V6A ' ENJOYING IN MULTIPLE ROOMS (ZONES) (yamaha.com)
12/14/2023 12:29:06 PM • Yamaha Audio... • Answered on Dec 14, 2023
Yamaha YST-FSW050 Ultra-compact powered subwoofer. It has bad vibration between 30-50 hz?
Question edited for clarity, full make model (what it is)'. Question moved to Yamaha Audio. It may be sympathetic vibration and is coming from something nearby. Put it on a folded towel or sit in the floor to test it. https://www.google.com/search?q=YST-FSW050+bad+vibration ..
12/9/2023 7:36:22 PM • Yamaha Audio... • Answered on Dec 09, 2023
How do I reset YAMAHA RX-V6A protection mode?
You must repair the amplifier first. Take it to an authorised Yamaha service centre.
12/6/2023 5:49:26 PM • Yamaha Audio... • Answered on Dec 06, 2023
Yamaha HTR-5750/5740. My Subwoofer not broadcasting
Visit 00_HTR-5750_U_EN.book (yamaha.com) and see page 59 (Troubleshooting).
9/23/2023 11:27:47 AM • Yamaha Audio... • Answered on Sep 23, 2023
No sound from Yamaha P155 Keyboard
9/19/2023 12:21:01 PM • Yamaha Audio... • Answered on Sep 19, 2023
How do I connect a SpeakerCraft BB275 to a Yamaha 5.1 receiver?
You can't do this. The SpeakerCraft is a standalone amplifier. The Yamaha is a Receiver and has its own amplifier. Putting amplified sound into a data input is not recommended and will cause component damage and overload 'clipping'. https://www.google.com/search?q=SpeakerCraft+BB275 https://www.google.com/search?q=Yamaha+5.1+receiver I deleted the two answers from AI Answer Bots as they are not doing you any favours suggesting it can be done in their waffling answers! ..
8/26/2023 12:13:06 AM • Yamaha Audio... • Answered on Aug 26, 2023
To fix or replace? My Yamaha RX-V663BL 7.1 Channel AV Receiver bought in 2009
Thanks for the compliments Gilbert. You have tried the reset so a Yamaha audio tech is the answer. This link will find you one close to where you live. There is probably a glass fuse on the power board, but you have to find out WHY the fuse blew? It is worth fixing in my opinion. https://www.google.com/search?q=yamaha+audio+repairs+near+me It does have a thermal fuse https://www.google.com/search?q=yamaha+rx-v663bl+no+power+on ..
8/22/2023 3:48:09 AM • Yamaha Audio... • Answered on Aug 22, 2023
Yamaha YST-SW150 Speaker Logo
10 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
yamaha sub woofer model nx sw150
  • Audio Players & Recorders
