20 Most Recent Grindmaster 1750 Espresso Machine Questions & Answers
Here is a recap of our phone conversation:
It was a pleasure talking on the phone with you. I was really exciting for me as well, as you are in the espresso business and you have an employee running a event with a portable set up and having a problem with a machine, and i can relate as i too also have a espresso company my wife runs, and I help customers on fixya. So I know exactly what your talking about, and i know the pressure you are under when a machine goes down, while you are trying to serve customers, especially when you have to help your employee over the phone.
The problem with the machine, is that you are not getting water to it and of course the red fill light is not on. Sense you just move the machine , portable set up down the road for example, that you said it was working fine, but when you just moved it to a new place that your employee wanted to sell some java, the machine does not now,fill with water or lets say pump water from the main water source.
Once we talked, it all main sense , and i feel i knew exactly what the problem is, You said this was a portable set up, meaning not hard water tapped. Meaning , your using like a five gallon fresh water supply, that you have a portable shur flow pump, that the pump sucks the fresh water out of bucket of water, and of course other ends goes into water inlet of machine. Nothing wrong with that, this is standard normally use and procedure for portable units, stands, portable building drive thru's etc.
You are suppose to have a inline filter,but you said, and i have done this too, sense it was just a little small event, you did not hook up the inline water filter. Yes, its possible, jets might have got clogged in machine, because of no inline filter, but i doubt it in this case.
Here is where i believe your problem is, and this happens all the time, to me on my locations and to all portable shur flow pumps. They get vapor locks real easy, especially when moved, as you just did. The pumps have a diaphragm inside and what happens especially when there turned off at the 110 plug and then moved, and replugged in and the hose back into the bucket,a couple things happen.
Number one. The hose line gets air in it and has to be primed ( vapor lock) primed is getting pump to start pumping, the shur flow pumps are great, but you kind of have to help them almost like siphoning gas. They are low voltage and 110 power, and not real strong for water pressure. What happens, when you unplug them and take hose end out of water, and move set up, and then try and hook it up, sometimes the diaphragm inside of the pump, gets stuck, and have to help get it flowing or should i say pumping. You can do this, by putting hose side in fresh water side, then other end of pump ( the line that goes to machine) take that hose off, then plug in pump, and un-plug. Use a small piece of wood, or lightly tap pump area on casing and then plug back in. Sometimes this will free up the diaphragm that will get stuck, if vapor lock. Do this a few times until you can get the pump sucking the fresh water out of the bucket and it starts squirting out the other end( that goes to machine),
Now this all being said, you stated on the phone, that the shur flow pump you have, is about 6 years old, from my own experience, they only last at full capacity for around 2years, maybe 3. I know I use them too, and have had my espresso company for 17 years. I always have a back up. Even tho your pump might be working, the diaphragm is getting worn, and I hate to say it, this problem will happen again, as it is getting worn. It probably is time at least to have a back up, just in case, you cant get it going. Eventually the diaphragm will get stuck and stay stuck, or what will happen, when you have it hooked up to machine, you will here the pump, pump every now and then, on its own for now reason, meaning, its leaking past the diaphragm, Here is also a web site that if you scroll at the bottom right, it has your machine to download your machine and the trouble shooting guide, The link to copy and put in your browser is https://www.coffeehomedirect.com/grindmaster/1750 that will show you everything, but it does not talk about the shur flow, as from my experience and yours that this is most likely where the problem lies.
Ok, been a pleasure and I hope this information helps you, i recapped this more than i had to, but i wanted to make sure we both understand what the problem is, and others who read this post, maybe it can help them. Thanks Again, Mike (Mr. Bean Man)
Grindmaster 1750... | Answered on Aug 13, 2011
If you've cleaned the nozzle on the wand and still nothing, is the wand hot to the touch when it is open? If no then the valve is blocked at the tube or the boiler connection.
Grindmaster 1750... | Answered on Apr 29, 2011
Pressure stat bad and or boiler is limed up.You may want to check the pressure line from tank to pressure stat is clear.
Grindmaster 1750... | Answered on Feb 12, 2011
Most grinders, especially the larger professional models will eventually need to have the grinding wheels (set of 2) changed out. They do wear down. The grinder will struggle as the burrs on the wheel dull out. This increases the time it takes to grind coffee and puts a heavy electrical load. Burnt out switches, tripping breaker, overheating, and burnt coffee grounds on espresso size are all symptoms of a worn burr set.
It's common to find; stones, nails, jewelry, and small loose things found around coffee counters in the grinding wheels or burrs. Have a qualified operator remove all beans and hopper to check and brush out burr set. This should be done every day. Talk to your vendor if you find nails as they can easily correct this with a magnetic pick up.
Another cause is very oily beans. Sometimes poorly roasted beans come out extremely oily which will gum up everything from the burrs, Moving parts, and electrical components. Disassembly of entire machines may be necessary.
.Final note; since you mentioned a switch swap. It's possible the switch is underrated for use in this machine. Most will work in a pinch but like a 'spare' tire in a car, they are only ment to get you to a service center for replacement.
Grindmaster... | Answered on Nov 12, 2017
this is a normal problem! first make sure you fill too top! also heat up urn with hot water prior to adding the hot coffee!
Grindmaster... | Answered on Dec 09, 2008
You can buy another one or you can you these tips:
There's nothing more invigorating in the morning than the smell of fresh coffee -- nor anything more frustrating than the sight of a coffee maker that isn't functioning as directed.
Fortunately, many repairs to coffee makers are simple to perform and require only basic tools. So, before you toss that coffee maker or defect to a coffee shop, consider how coffee makers work and what to do when they don't.
If these won't work email me: [email protected]
Coffee Makers &... | Answered 9 hours ago
I have the manual. I just purchased the coffee maker friday. where do you want me to send it?
Coffee Makers &... | Answered 2 days ago
Sounds like the motor underneath the frother unit has broken down. If you still have warranty, then go to the retailer. Otherwise you maybe can check the unit by opening it from the bottom and checking all the resistances of all the components with a multimeter to figure out what went down.
Coffee Makers &... | Answered 3 days ago
It is blocked and needs flushing!
take all parts out and clean thoroughly by soaking the jets and nozzles.
Coffee Makers &... | Answered on Jan 10, 2021
Grindmaster 1750 Espresso Machine Logo
3 questions posted
Top Grindmaster Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Ross Keen
Are you a Grindmaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Grindmaster Coffee Makers & Espresso...
  • Grindmaster Coffee Makers & Espresso...
Most Popular Question
get hot water pump works but no steam
  • Coffee Makers & Espresso Machines
