20 Most Recent
B&W DM603 S2 Speaker Questions & Answers
Two questions:
1) I have a
These are very good speakers with three speakers in the enclosure.
1. Check to see if the wires broke on the tweeter that fell out. A friend with a screwdriver can remove the bigger speaker to inspect the damage. I think the tweeter is probably OK.
2. It is possible to swap tweeters with your other unit to ensure it is the tweeter and not the wiring or crossover. There is a small electronic unit in the cabinet that serves all three speakers.
3. You most certainly replace this tweeter to get the speaker system back to specifications.
I am unsure about the HF or LF connections. If you have an instruction manual, it would be in there. HF is probably High Frequency; LF is probably Low Frequency. Whoever sells the tweeter will know the answer to that question. Lacking any other information, I would connect to the other set & see if I could hear a difference in low frequency response.
Gary
Can i bye just the box
Not to sure about the box,but i have just Brought a couple of tweeters from B@W for the 603s2.They where really good to deal with.The lady that i spoke to had a list of all the parts they do and the prices and also delivery cost so it was all very easy to work out.I have nothing to do with B@W what so ever.Im the man in the street.Just trying to help.Go direct to B@W u.k rather than a dealer the number and all in fo is here.hope this helps.
B&W Group Ltd - UK Spares & Repairs (UK Customers Only)
Service Department, Dale Road
Worthing,
West Sussex
BN11 2BH
Tel:
(01903) 221700
Fax:
Email:
[email protected]
Web:
http://www.bowers-wilkins.co.uk
Hi
ive got a b&w as2
Are you running this subwoofer via an LFE (RCA line level) connection, or via high level (speaker lines in and out of the subwoofer)? There may be different ways to hook up this unit and it would be helpful to know how you have the unit connected. Thanks!
5/4/2011 6:16:55 PM •
B&W Audio...
Answered
on May 04, 2011
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
