20 Most Recent New Bright Remote Control 1:12 Scale Pro Wolf Flat Track Racer 14"R/C Pro Wolf, Flat Track Racer Questions & Answers
The sensor is a resistive load sensor. The resistance changes as the motor gets hot. Solder the wires back onto the board and whilst keeping the model off of the ground, put it into drive mode. If it doesn't go, then wet your finger and bridge the two solder points on the sensor. Don't worry, you will not get any electric shock as the voltage and current are too low.
If it still doesn't drive, then wiggle the motor wiring at the motor. If still nothing, then press lightly on that sensor pcb. There may be a broken track on it. If it is broken, then you cannot solder it. You then need to go to Maplins (if in the UK) and buy a small bottle of pure silver paint. Where the solder points meet the circuit resistive track (it'll be black carbon looking), paint one blob of silver conductive paint onto each of the track beginnings. Let those dry (five minutes) and then try it. It should work. The silver paint will only work if the wet finger trick on the black carbon track works. If no carbon track, then it may be a thermal resistor (thermistor). Replace it. Maplin sells them too, so just buy a few different types (very cheap) and temporarily solder one in place until it works.
New Bright... | Answered on Nov 13, 2013
Fixya does not sell New Bright parts.
New Bright Toys | Answered on Mar 16, 2019
What size batteries does the 1986 D and W R.R Denver express take
New Bright Toys | Answered on Jan 02, 2019
CHECK FOR SWITCH ON BOTTOM OF TRAIN
New Bright Toys | Answered on Sep 24, 2018
The controller and the car must be matched. Sounds like both are matched using the same frequency. Look at the instructions for changing the controller and car to a different frequency Then change one car and controller. try here
Technical Documentation New Bright Industrial Co
for info
New Bright Toys | Answered on Jan 12, 2018
New Bright Remote Control 1:12 Scale Pro Wolf Flat Track Racer 14"R/C Pro Wolf, Flat Track Racer Logo
1 questions posted
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
gerry bissi
Marvin
Marvin
Are you a New Bright Toy Expert? Answer questions, earn points and help others
View Most Popular
New Bright Toys
  • New Bright Toys
Most Popular Question
took body cover off new bright wolf
  • Toys
