20 Most Recent
Giottos MT 8160 Tripod Questions & Answers
Giotto MT 8160
Call us at 800 735-4373 in the USA and we will send you the replacement part.
Giottos MT-8180 tripod parts
So is this knob positioned on the lower, centre tube between the legs? Could you post photos of the Knob and where it fits to the tripod?
Most tripods have adjustment for 4 settings. Height, rotation, Tilt and mounting plate angle. We'll need to work out which one of these it's for. Height is usually a crank handle so it's possibly not that one. The other 3 are usually a bolt with a moulded cap to make turning it easier. Some tripods have a screw clamp on the body to lock the legs into the open or closed positions.
Comment below with more information and I'll try to help you more.
5/31/2023 3:20:19 PM •
Giottos...
Answered
on May 31, 2023
How to remove the head of a Giottos camera tripod
Most tripods have a 1/4" thread attached to the centre column, which then screws into the base of the head (some may have a 3/8" thread, but the principle is the same).
Grasp the head firmly in one hand, the shaft firmly in the other, and rotate the head counter clockwise to remove the old head. If it has been in situ for some time, it may be stiff to rotate.
Once you have removed the old head, lubricate the threads on the centre column, then attach the new head, rotating this one clockwise.
If the old head will not unscrew under firm manual pressure, remove the centre column and place in a vice, packing it with wooden battens to protect it. Then attempt to unscrew the head, using a mole grip or similar if necessary.
9/14/2016 8:32:33 AM •
Giottos...
Answered
on Sep 14, 2016
Mg8240b
-If you need to order repair parts for your Giottos MG8240b tripod..., (vs accessories such as camera plates)..., I would suggest that you use the following link to contact the Giottos distributor in your country. They should be able to supply you with parts diagrams, this will allow you to provide them with the info to get your tripod up and running again.
GIOTTOS IND INC
-Hope this helps.
Peter
9/4/2014 2:05:36 AM •
Giottos...
Answered
on Sep 04, 2014
GIOTTOS tripod centre column require clamp to hold the column secure
That will depend upon which model and what is damaged/worn/broken. Without more info there is no help. you can send the tripod to:SpartanPhotoCenter197 East Saint John StSpartanburg,SC 29306We can give you an estimate to repair after we find out what model/ what part you may need. Generally repairs are $ 25 + Parts + return shipping.
12/15/2012 12:26:59 AM •
Giottos...
Answered
on Dec 15, 2012
Giotto Aluminum Tripod # 9160
Call us at 800 735-4373 regarding serving Giottos tripods and for our address to get this properly repaired. It does not need lubrication.
9/4/2011 8:25:53 PM •
Giottos...
Answered
on Sep 04, 2011
