20 Most Recent
SuperMicro MB X6DAL-TB2-0 E7525 RT (MBDX6DALTB20) Motherboard Questions & Answers
Graphcis card wont work
You have received some wrong information.
This motherboard has a PCI-e x16 slot(ver1.0), two PCI-X 66MHz, and two PCI 33MHZ slots..
The video card must go in the PCI-e x16 slot.
The x8 lanes are hardwired from the Tumwater chipset to the BCM5721 LAN chip, and are not accessible for use.
There is no x8 lane slot on this motherboard.
Does not detect sata dvd
I think ur motherboard not support sata dvd drivers. so Install the motherboard drivers. or cheak the sata cable or drive.
Supermicro x9sra Boot up
file:///C:/Users/Wajiha/Downloads/MNL-1281.pdf
http://kernelpanik.net/boot-selection-menu-on-supermicro-x9sra/
Intel d915GLVG mother board vrm is short and fun dose not work
An electrolytic capacitor has failed.
If one has failed it indicates that the board has overheated, and many other components are also weak.
This Intel board is not of good quality.
Replace with SuperMicro or Tyan, and improve the cooling airflow in the case.
H8dce no audio
Usual cause.
Under the Chip Set Menu in the BIOS
Under South Bridge Configuration
The setting Audio CODEC Interface has been set to disable.
Linux drivers serial
The first place is always the Debian Linux website, because most Linux packages are derived from Debian.
Post code 38
"The BIOS can not shadow the ROM into system memory."
This is usually caused by the ROM on a card trying to use the same memory space.
Remember all of the ROMs have only the memory addresses from C800 to FFFF in the first megabyte available for shadow.
This was designed in in the first IBM PC and remains to this day.
Remove the other cards, and turn off both system ROM shadow, and video ROM shadow.
PDSMI
If you are good with a soldering iron the capacitors can be replaced.
Make sure you can wick the excess solder out of the holes.
Replace only with Japanese capacitors, and increase the airflow in the case and around the capacitor.
This is usually a sign of overheating.
