20 Most Recent Crosley CR19CD CD Player Questions & Answers
If you mean that there is no electricity reaching it then a blown fuse in teh mains plug is the most likely.
If you mean that electricity is reaching the player but the turntable isn't going round then you probably need to replace the rubber drive belt - purchase online (try Amazon) searching by make and model number.
You will need to gain access to the underside of the turntable to change the belt - normally done by unscrewing teh base.
Crosley CR19CD... | Answered on Feb 27, 2011
The belt needs replacing
Crosley CR19CD... | Answered on Jan 06, 2011
Hello Tom, you would have to measure if the engine gets power, also control the key that drives the engine when it starts
Check if you can move the motor shaft with your hand, to confirm that it is not locked
Good luck with the checks
Greetings Franco Dosil
Hola Tom, tendrias que medir si le llega alimentacion al motor, tambien controlar la llave que acciona al motor cuando arranca
Fijate si puedes mover el eje del motor con la mano, para corroborar que no esta trabado
Suerte con los chequeos
Saludos Franco Dosil
Crosley Audio... | Answered on Apr 19, 2019
Crosley CR19CD CD Player Logo
9 questions posted
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Audio Players & Recorders
Most Popular Question
record player turn but plugged in
  • Audio Players & Recorders
