20 Most Recent
Nostalgia Electrics Classic Music Jukebox Retro Nostalgia AM/FM Radio CD Player Shelf System Questions & Answers
Hi i hav a 470 rockola jukebox it dosnt seem to
The problem is probably in the keyboard. Clean all the contact switches you can get to with very fine sandpaper. The reason it is stuck is it is waiting for that third selection to complete the circuit.
4/16/2016 9:56:10 PM •
Nostalgia...
Answered
on Apr 16, 2016
The third select button will not stop down
I have a model 464 and my problem was similar but mine was the second digit.I replaced the p c board in the selection control box and my problem was gone.I would check the selection control box.Hope this helps
1/17/2013 5:16:43 AM •
Nostalgia...
Answered
on Jan 17, 2013
NSM Proformer cd jukebox flashes er73 and will not
error 73 means error during grip from magazine check for lift jamming,check function and adjust,i had one recently the same fault found it easy to replace the cd changer complete for 65.i do have the manual and service guide if you need one just email me
9/17/2010 8:28:37 PM •
Nostalgia...
Answered
on Sep 17, 2010
I have a Seeburg MCU3 Prelude - had is repaired a
No, but like any machine, it does need lubrication once in a while. You should purchase a manual for it (eBay).
If the clutch has become stuck, it's time to call in a pro.
Are you sure it's in "PLAY" mode? Check to be sure the service switch is in "PLAY."
Does the motor turn?
If yes, try pressing the reject button on the back. Maybe it's stuck thinking it's playing a record in an empty slot (clamp arm will be against the turntable). There is also a manual trip lever just to the right of the tonearm. lift up on it if the motor is turning and see if that triggers it. Go ahead, it won't hurt you.
if the motor itself has frozen up from lack of oil, try putting some light machine oil (NOT 3-in-1 or anything paraffin based) in the oil cups on the side of the motor and letting it sit for a few hours. Then, turn the motor shaft by hand a little. This may free it up. if so, count your blessings and call someone in to give the whole mechanism a proper lubrication or something else will eventually seize up or wear out.
Good luck.
2/28/2010 8:11:29 AM •
Nostalgia...
Answered
on Feb 28, 2010
Cracked rowe cover
THIS IS A COMMON PROBLEM. THE ONLY SOLUTION IS TO REPLACE THAT DOME.
GLUING WILL NOT WORK. APOXY WILL NOT WORK. THERE IS A LOT OF PRESSURE
AT THAT PLACE.
REPLACE THAT DOME IS THE WAY TO GO. GET N FRIENDS TO HELP, OR YOU WILL BREAK THE NEW DOME.
[email protected]MAME IS SEYMOUR LEVITT
COMPANY NAME IN-HOME JUKEBOX REPAIR
6362273300
746 HENRY AVE BALLWIN MO.
6/16/2009 2:48:17 PM •
Nostalgia...
Answered
on Jun 16, 2009
How do i change needle on record player no
release the orange case from the back and slide forewards.Note,use athin knife blade to ease the case sides 2no. from holding points on head.BUT THERE MUST BE A BETTER WAY???.
11/26/2009 5:15:05 PM •
Nostalgia...
Answered
on Nov 26, 2009
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
