20 Most Recent
Manitowoc ID-0452A 420 Lb Full Size Cube Ice Machine - Indigo Series Questions & Answers
My manitowoc series 420 has a code telling me the compressor discharge temperature
Which code is that? I don't see that in the service manual. There is an E09 that indicates that during the first six minutes of freeze the discharge temperature was below the average of the last 6 cycles. I have searched from E01 to E31 and don't see the code you indicate but I would say you either have a low refrigerant charge, a flooding TXV that is allowing too much refrigerant flow into the evaporator and not allowing enough flow to be diverted into harvest, or a weak compressor. Reset the unit and check the temperatures on the display while its running and time a freeze cycle. Should take about 15 minutes to make ice.
1/5/2015 5:17:32 PM •
Manitowoc...
Answered
on Jan 05, 2015
Why is my Manitowoc SM50 ice not dropping?
Greetings,
when this occurs, please add some salt to the idea in order to stop the ice from sticking together as much. That's the temporary fix. For any other machine, I would think this was an oil issue. That's the parts that create the ice stop-up due to friction caused by a lack of oil. I'm guessing that every time you clean the machine, you decrease the friction between its parts due to the water/soap that you use, but then the oily soap residue gets used up, and the issue returns. Please test out my idea.
Thank you.
3/11/2023 8:22:31 PM •
Manitowoc...
Answered
on Mar 11, 2023
I have a manitowoc r-12 system 200 I can't get to make ice what can I do
First, this us a very old system and probably needs to be replaced if it really is an R12 system. The unit is probably at least 40 years or more old since they stopped producing R12 about 1970's. If your manitowac ice machine is usable still, it probably has lost its charge and will need to be refilled with a suitable refrigerant. I actually still have a jug of R12, but I generally charge systems with the only substitute still available R420 if you can find someone who still sells it. I saw that both refrigerant were being phased out and purchased a couple of jugs and only have a little left. My suggestion if you want this ice machine in operation again take it to an ice machine repairman and have him repair it. Good luck.
5/29/2019 11:41:03 AM •
Manitowoc...
Answered
on May 29, 2019
