20 Most Recent Crate Cfs2 2 Button Footswitch (For Amps) Questions & Answers
Request from Crate
Crate Music | Answered on Nov 01, 2020
bad output transistors.
Crate Music | Answered on Aug 21, 2019
Clean the volume and tone pots with de-oxit cleaner
Crate Music | Answered on May 02, 2019
Try with a on/off footswitch Wrong cable, or bad PCB connection switch on main tone board.
SLM sold the company years ago to Loud audio. Its only supported online now. Loudaudio.com
Power supply capacitors failed. This is a common problem with 1990's crates, also the power on "POP".
https://www.amprepairparts.com/schematics.htm
Use the GX-65, its the same preamp shopwn just with 2 power amp sections
There is a short somewhere, check your wiring and solder points.
Crate Music | Answered on May 01, 2019
If sure that power is reaching and getting into unit, then confirm that a signal is also reaching unit. If both are positive, then your gear is FUBAR if signal is going into correct input.
Crate Music | Answered on Mar 03, 2019
1. Sounds like it's the input jack., but it could be the volume knob. Have you tried turning Gain1 and Gain 2 or the Clean Channel volume? Try them first when you're plugged in to the jack on the left , then when you're plugged in the back. If none of these work, it's most likely the preamp. 2. Even if the preamp is shot, there's a quick fix - get a guitar preamp or an effects pedal - they have volume and tone controls. 3. Finally - many pros just plug into the aux jack(on the rear panel) and control the volume and tone through their instruments. Hope one of these works. Good Luck.
Crate Music | Answered on Dec 26, 2018
Contact the Crate Service Department at 1-800-738-7563 or 314-569-0141 (8:30am-5:00pm central time, Monday-Friday) to order any parts and/or schematics.
Crate Music | Answered on Aug 05, 2018
Web page with schematics and requests:
http://music-electronics-forum.com/t26486/
http://music-electronics-forum.com/attachments/15279d1315547654-crate-vc6112.pdf
http://music-electronics-forum.com/t16609/
http://music-electronics-forum.com/attachments/7268d1260872380-crate_vc6112_271pwa_5.pdf
http://music-electronics-forum.com/attachments/7269d1260872394-crate_vc6112_271sch_5.pdf
http://music-electronics-forum.com/sitemap/f-60.html
User guide at link below from 1998 has mailing address in St. Louis.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwit2JO06LbZAhVG2GMKHflPAxEQFgg4MAI&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F6%2F6d0e7f56-c06e-40bc-9925-bb1c66338de7.pdf&usg=AOvVaw1Qy5Pze8vKekErxgjmMg0U
Crate VC 6112 Owner Manual
Crate Music | Answered on Feb 21, 2018
Crate Cfs2 2 Button Footswitch (For  Amps) Logo
3 questions posted
Top Crate Music Experts
Ngoro
Are you a Crate Music Expert? Answer questions, earn points and help others
View Most Popular
Crate Music
  • Crate Music
Most Popular Question
need amp schematic crate model vc6112
  • Music
