20 Most Recent Peavey Valveking Head Questions & Answers
and do you need one?
Peavey Valveking... | Answered on Sep 20, 2014
that depends on your cabinet(s). if you have an 8 ohm cabinet you want to use your 8 ohm out. if its a 16 ohm cabinet you want the 16 ohm out.. etc.. etc. etc.. owners manuals will tell you these specs
Peavey Valveking... | Answered on Sep 01, 2011
The answer all depends on the impedance of your speaker(s). A single speaker can be plugged into either jack. Set the switch to the impedance of your speaker. If you use two speakers, set the switch to one half of the impedance of the lowest impedance speaker. Very few speakers are 16 ohm types. Most are 8 ohms and some are 4 ohms. You could plug an 8 ohm into each of the jacks and set the switch to 4 ohms for example.
Peavey Valveking... | Answered on May 28, 2011
Same thing... they probably broke both jacks. Sometimes the guts of the jack is broken and it doesn't appear to be broken but is broken internally. You may find broken solder on the pins to these jacks as well.
Note that the two input jacks have a different gain.
Here is schematic: http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Peavey Valveking... | Answered on Dec 02, 2010
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
Peavey Valveking... | Answered on May 30, 2010
Serials
Peavey Predator serial numbers - Peavey Forum
forums.peavey.com > Instruments > Peavey Guitars
Aug 20, 2011 - I am looking at a very nice, older Predator. Can someone explain the serial number codes so that I can get an idea of this guitar's age? Peavey list of guitars & years made - Peavey Forum
Jul. 13, 2011
predator serial number - Peavey Forum
Jul. 1, 2015
Peavey Predator guitar serial number - Peavey Forum
Sep. 28, 2010
Freshening up a Peavey Predator? - Peavey Forum
Dec. 8, 2013
More results from forums.peavey.com
List of Peavey guitars - Wikipedia
en.wikipedia.org > wiki > List_of_Peavey_guitars
Peavey Guitars are electric, acoustic, and electric bass guitars branded by Peavey Electronics. Contents. 1 List of models. 1.1 Guitars; 1.2 Bass guitars; 1.3 Acoustic guitars; 1.4 Serial numbers ... Predator (Kahler Flyer tremolo made in USA 1985-1988); Predator (Power Bend tremolo made in USA); Predator AX (made in ... ‎List of models · ‎Guitars · ‎Bass guitars · ‎Serial numbers
For values, go to eBay and in the filter, put Prices Fetched.
Peavey Music | Answered on Feb 03, 2021
Our new VT Series Classic is the latest version of the ever-popular tube type Peavey Classic. ... innovations incorporated into our larger and more powerful amps. ... utilizes an entirely different type of reverb unit and associated drive circuitry and ... distortion effect is mixed with the clean signal when in the Automix mode.
Peavey Music | Answered on Nov 20, 2020
everybody can win upto $15k always from home by way of running on the web. i've gotten $17294 a month ago through doing this simple and easy career online from home. Its a simple and easy career to do at the net and even a little child can carry out this interest from home. all people can land this position now by way of simply faucet on the relationship given underneath... go to home media tech tab for more detail assist your heart
HERE? w­w­w.2­3­p­r­o­f­i­t.c­o­m
Peavey Music | Answered on Sep 19, 2020
Sounds like a power supply failure. I think you need a service call to let a tech look at it. I googled around and couldn't find a free service manual, but if you're technical and have a 'scope, you might try that route. At $400, I'd try to get it fixed if I were you.
Peavey Music | Answered on Jun 14, 2020
If the resister is still intact, upload a picture of it and I will tell you the value...
Peavey Music | Answered on Feb 26, 2020
If you have any cables from the effects inserts section of the board inserted, disconnect them. Check ALL sends levels. Check effects processor for L.E.D. signal. .(Assuming you are using the internal effects.)
Here is an excerpt form the manual:
https://assets.peavey.com/literature/manuals/80301359.pdf
Peavey Music | Answered on Oct 23, 2019
Peavey Valveking Head Logo
Popular Tags
8 questions posted
Top Peavey Music Experts
midland10
rhodesworks
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
fishman
  • Music
