20 Most Recent Homelite Mighty Lite Blowervac Questions & Answers
Whilst I cannot offer a definite solution to this problem, it is worth disassembling the carburettor looking for dark brown material that collects if you don't drain the fuel tank after each use. I have started running all of my petrol engines dry to avoid this problem of fuel evaporating leaving coagulated oil in the carburettor as a membrane. You won't damage a good motor by doing this since as you should have lubrication for the piston rings right up until the agonal stroke.
Homelite Mighty... | Answered on Jul 08, 2019
Hose just below primer bulb goes into tank and is shorter longer hose with fuel filter goes to other line on carb.
Homelite Mighty... | Answered on Feb 06, 2019
Turn both H and L adj. crews all way in to right counting number of turns on each. Back each one out 1 1/2 turns engine should start adj. H by holding throttle to maximum and adjusting until max rpm then adj.L for idle and very little hesitation when quick throttle. You may the have to tweet each.
32:1
You need a new diaphragm. A carburator kit,
Homelite Mighty... | Answered on Dec 20, 2014
I believe Husqvarna now owns the Homelite brand
Homelite Mighty... | Answered on Oct 21, 2014
Who put in a new carb? Ask them. Check for air leak in fuel line or clogged filter at intake inside gas tank. Maybe intake tube is not down in the gas tank far enough.
Homelite Mighty... | Answered on Jul 24, 2014
Hi. This link,
http://manuals.homelite.com/documents?page=5
is to the homelite page where the manuals are, however, there are 4 different models of the handheld blower you have. Either way, if this is a really new model, there may be no way to adjust the carburetor, as due to emissions standards, there may not even be any idle screws, but if they do exist, the head ma be whats called "pacman", as it looks like a little....yeah...pacman.
Homelite Mighty... | Answered on May 08, 2014
there is no air filter on my 26bv blower
Homelite Mighty... | Answered on Nov 15, 2013
Does it have a primer,to prime about 3-5 times,it may be bad,sucking in air and not supplying gas to carb,replace,they are inexpensive,home depot or lowes should have or look up on line,but you may have to pay shipping.
Homelite Mighty... | Answered on Sep 21, 2013
Can you find the model number on the Homelite Mighty Lite BlowerVac?
For the UT08520 and UT08921 26cc blowers and the UT08550 and UT08951 blower vacs, you can mix the Homelite Premium Exact Lubricant with gasoline following the label directions. For other synthetic oil additives, use 2.6 oz of additive per 1 gallon of gasoline. (It's 20ml to 1 l if you use the metric system.) That's a 50:1 ratio (gasoline to additive).
Many Homelite Blower manuals are available here: http://manuals.homelite.com/documents?page=5 . You should try to find your exact model and then check the manual to confirm that your model blower vac uses this same ratio of oil to gasoline. You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Homelite Mighty... | Answered on Sep 06, 2013
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Homelite Mighty... | Answered on Nov 12, 2012
The fuel pump side goes: carb body, diaghram, gasket, cover.
The metering side ( side with the needle) goes: carb body, gasket, diaghram, cover. On the diaghram, the side with the larger disc and the holes around it and the nub in the center goes down toward the needle lever.
Any adjustment needles can be set at 1 and 1/2 turns out to start. Turn out to richen. If it falls on its face and bogs when you throttle up then its lean and needs to be richened up.
Homelite Mighty... | Answered on Oct 08, 2012
Homelite Mighty Lite Blowervac Logo
Popular Tags
97 questions posted
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
View Most Popular
Homelite Garden
  • Homelite Garden
Most Popular Question
not know oil gas ratio mix buy
  • Garden
