Raypak 2100 Pool... | Answered on Feb 14, 2018
Raypak 2100 Pool... | Posted on Dec 02, 2017 | Be the first to answer
The
E in your model number means it is an electronic ignition...you do not have a
pilot. ROL means your flame rollout sensor is open. Either the wiring to the
sensor or the sensor itself is faulty or there is a flame rollout issue causing
the heater to shut down for good reason and the cause of the rollout needs to
be determined and corrected in order to run the heater.
The
replacement part for the switch is 006035F. It will need to be replaced since
one it burns open it is shot.
Causes
for flame rollout issues include blocked gas venturies on the manifold causing
a sudden and violent ignition of gas as it lights the burners or blockage of
heat and flue gas from escaping across the heat exchanger and out the top of
the heater.
If
this answer does not fix your problem, please comment with additional details
prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated
once your problem is solved!
John
Raypak 2100 Pool... | Answered on Sep 13, 2011
Raypak Pool &... | Answered on Dec 23, 2020
Raypak Pool &... | Answered on Sep 12, 2020
Raypak Pool &... | Answered on Aug 25, 2020
Raypak Pool &... | Answered on May 28, 2020
Raypak Pool &... | Answered on May 01, 2020
Raypak Pool &... | Answered on Jun 20, 2019
Raypak Pool &... | Posted on Aug 11, 2018 | Be the first to answer
Raypak Pool &... | Posted on Aug 04, 2018 | Be the first to answer
Raypak Pool &... | Posted on Jul 16, 2018 | Be the first to answer
4 questions posted
177 Questions
43 Questions
49 Questions
