20 Most Recent
Intex 18 ft x 48" Easy Set Inflatable Swimming Pool+Pump () Questions & Answers
What would be the best automatic pool cleaner for intex 18 x 48 easy set
the vacuum you are using is probably the best for the system you have. if you want a REAL pool vacuum, get a REAL pool. there is a reason that these are considered disposable pools. dont get me wrong, any way to cool off is great and these pools allow people this 'luxury' at a reasonable cost but they are assembled with low end, non standardized equipment that doesnt match with traditional pool equipment.
The piece on the top of the filter keeps coming
On top of the pump unit, is a large wheel-type screw. With the pump on, all the air must be purged from that pump in order for it to work properly. Every time you plug in the pump, you must press the red button on the plug. It's a saftey feature, otherwise you won't have any power.
The water level in my pool dropped over a foot
check for any signs of water by hoses/pump....outside of pool on ground and leaks by under the inflatable ring outside...good luck!we had a neighbor or stray cat that would jump onto ring to drink!caught it after seeing "foot prints"....had to wait and catch it...but scared her with hose and patched pool...had teeny points from claws!
I have the 18 ft x 48" intex easy set infletable
This should be easy ... a foot of water? I would suggest you are leaking out the bottom. do you have a mask and snorkel? Watch the bottom from a floating position ... you might find the hole ... there are underwater patch kits for this very purpose.
Water pressure in to the pool has vanished. No
CHECK FOR A BLOCKAGE IN BETWEEN THE OUTLET AND THE PUMP MAY HAVE HAIR OR TRASH SIDE OF THE PUMP AS THERE IS A BUILT IN STRAINER THERE. ALSO CHECK YOUR PLUNGER VALVE AND SEE IF ITS CLEAR.
Air leak in ring
JOJO I FIND THAT THE SOAP YOU USE TO BLOW BUBBLES WITH WORKS THE BEST, BLOW THE RING UP REAL GOOD, AND GO SLOW. I HAVE USED CELLOPHANE TAPE TO FIX LEAKS ON MY WATERBED
