20 Most Recent Waterco Baker Hydro 80K Btu Titanium Manual Pool Heat Pump Questions & Answers
I had the same problem last week. I called a technician who found out that the capacitor was defective. Cost 50$ + the service call.
If the capacitor is working, it might be the compressor...
Waterco Baker... | Answered on Jun 08, 2014
make sure your filter is clean, heat pumps are fussy about too much back pressure. you might try it with the filter cartdrige renoved
I ve got the same prblm ,
I ve lread changed thermosensor and condensator
no change
Waterco Baker... | Answered on Aug 24, 2013
in which area do you live, as if the air temp is colder than the pool water it is evapoartion most likely, Test the water coming out of the heater against the water in the pool, if your pool is salt water and the water coming from the heater has no salt then your pool is not leaking, as the heat pump is like an air conditioner it will produce condensate Water from the air. in steamy weather there will be alot of water. David PoolWerx Brisbane
Waterco Baker... | Answered on Mar 10, 2013
SINCE THIS IS A DIY ER MOSTLY FORUM WE HAVE NOT SEEN EVERY PROBLEM IN THE ENTIRE WORLD SAD TO SAY BUT KEEP THINKING ABOUT IT AS DIYERS DO AND PERHAPS THE SOLUTION WILL MAGICALLY JUMP OUT AND BITE YOU SOUNDS LIKE THE THERMOSTAT MIGHT BE WHERE TO START LOOKING
Waterco Pool &... | Answered on May 24, 2020
NFL code: No water flow, not sufficient water flow through the pool heat pump or the water pressure switch needs to be adjusted or is defective.
Waterco Pool &... | Answered on May 08, 2020
Will either be the start capacitor (in the box on top of the motor) or something binding the impeller or potentially both.
There is a fan cowling on the rear end of the pump try this;
- Turn the power off
- Remove the cowling
- See if the fan allows you to spin freely/easily the pump
BE SURE nothing could become entangled in the fan
- Turn pump back on
- If it starts, probably something on the impeller side
- If it doesn't but will start with a little turn of the fan probably the capacitor. Get a new one from Jaycar or RS components
Remember to put the cowling back on safely.
Waterco Pool &... | Answered on Mar 22, 2019
Try Googling (waterco)(4555100E)(manual) without parens.
Waterco Pool &... | Answered on Mar 13, 2018
Waterco Baker Hydro 80K Btu Titanium Manual Pool Heat Pump Logo
14 questions posted
Top Waterco Pool & Spa Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Waterco Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Waterco Pool & Spa
  • Waterco Pool & Spa
Most Popular Question
waterco aqua heat titane 101 fan come
  • Pool & Spa
