20 Most Recent
Hayward 1 Hp 2 Speed Super Pump Inground Pool Pump ( Ssp2607 102 ) () Questions & Answers
I replaced the motor on my super 2 pump with a new
Most likely leaking from either the shaft seal, or the valute seal (big seal plate o-ring). When you replaced the motor you should have also replaced the shaft seal. If not go back and do that whether it's leaking or not. If you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing. If it's coming from the motor then the shaft seal is leaking, and the water is traveling along the shaft and out the bottom of the motor. This will eventually get into the motor and seize up the bearings. If it's coming from the valute seal, then you need to either replace or re-seat the seal. As a general rule you should always replace the shaft seal, and diffuser and seal plate o-rings when you replace the motor or split the seal. I'm not as familiar with the 2 speed hayward super 2, but the standard super 2's have a small ribbon seal, often called a rubber band. They are infamous for going bad especially after pulling the pump apart.
How to install hayward motor?
Just the motor? Three things you must consider: There are 4 bolts that fasten the motor to the pump housing. You need to determine 110 Volts or 220 volts - 220 will run the pump more efficiently. Bonding. Your motor must be bonded to all other metal parts of your pool system.
How do you wire a
you may have got a four-conductor wire; normally, only a three conductor is required for a power cord (again, if that's what you're describing.) The black and white would normally go to L1 and L2, and the green would go to the ground screw. (This should be demonstrated on the wiring diagram on the motor.)
Check out thanks.
Motor humming will not turn
You can undo the bolts that are holding the motor to the pump. That will let you spin the impellar of the pump .. Please withdraw it slowly and observe how the extra pieces fall out because if you get them in wrong the pump will not work correctly, While you have it apart , try and spin the impellar and switch the motor on , seeing if it will run if you hand start it .. if it will not run , then you probably need a new motor .. Most pool shops can test the motor for you to confirm that .
Please Vote !
When i put my hose in to vaccum i lose suction but
Are you filling the hose with water before you put your hose into the skimmer? Put your vacuum in the pool - put the other end of the hose over a discharge ... when the air bubbles stop coming from the bottom ... , put your hand over the end of the hose and then stick the hose into the skimmer suction.
HF code on hayward 200fdn pool heater?replaced gas valve still have same code.What now?
HF
Flame present with gas valve "OFF" error
If flame is sensed with the gas valve off the control will go into lockout. The blower will run until error condition is corrected. When corrected, control will run blower for 5 s then automatically restart after 2 minutes.
the error might be caused by a faulty flame sensor. i have heard of this happening the other way (carbon blocks sensor causing no ignite)
New XtremepowerUS 2HP In-Ground Swimming Pool Pump Variable Speed 2 Inlet 230V High Flo w/ Slip-On Fitting, i turned it on after 2 mins switch from high to low then shut off and get very hot.
All electric motors run hot and pool pumps are no different. But how hot is too hot for a pool pump? The first test is simply whether you can touch the motor or not. Under normal operating conditions, the motor end of the pump is hot enough that you can barely touch it - but not searing hot.Best to you.https://www.google.com/search?q=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&newwindow=1&sxsrf=AB5stBhpriuNhnfXLYYTg7tuS-LWwW262g%3A1690815381903&source=hp&ei=lcvHZKH_NOHi9AOquJjADw&iflsig=AD69kcEAAAAAZMfZpVdAAi94QXZiwKfN3nArsWv-Gm1z&ved=0ahUKEwjhnd6RmrmAAxVhMX0KHSocBvgQ4dUDCAo&uact=5&oq=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&gs_lp=Egdnd3Mtd2l6IkpYdHJlbWVwb3dlclVTIDJIUCBJbi1Hcm91bmQgU3dpbW1pbmcgUG9vbCBQdW1wIFZhcmlhYmxlIFNwZWVkIHJ1bm5pbmcgdGVtcEgAUABYAHAAeACQAQCYAQCgAQCqAQC4AQPIAQD4AQL4AQE&sclient=gws-wiz#kpvalbx=_sMvHZMuPJPez0PEP3M2LgAY_44
How can I test if my Hayward gas heater water pressure is working??
Testing the water pressure of your Hayward gas heater is a relatively simple process. Follow these steps to check if your water pressure is working properly:
- Turn off the Gas Heater: Before performing any tests, make sure the gas heater is turned off to avoid any potential accidents or injuries.
- Check the Pressure Gauge: Locate the pressure gauge on your Hayward gas heater. It is usually located on the front panel of the unit or near the plumbing connections.
- Observe the Pressure Reading: The pressure gauge will display the current water pressure. It is typically measured in pounds per square inch (psi). The optimal water pressure for most pool heaters is usually between 15 psi to 25 psi, but it's essential to check your heater's manual for the specific recommended pressure range.
- Turn on the Pool Pump: Ensure that the pool pump is running, as it is responsible for circulating the water through the heater. The water pressure will be at its most accurate when the pool pump is operating normally.
- Monitor the Pressure: While the pool pump is running, observe the pressure gauge to see if the water pressure falls within the recommended range. If the pressure is below the minimum recommended level, it may indicate a circulation issue or a problem with the pool pump.
- Check for Leaks: While testing the water pressure, inspect the heater and the surrounding plumbing connections for any signs of leaks. Leaks can lead to reduced water pressure and affect the heater's performance.
What is a 1F code on the hayward pool heater
The code you are referring to is actually IF, not 1F. It stands for ignition failure.
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
