20 Most Recent Hayward SP3015X20AZ 2 HP SUPER PUMP II SP3015X20AZ Questions & Answers
sounds like motor over heating or bad start up capacitor
Hayward... | Answered on Feb 10, 2018
Friend had similar problem... Clean filter, added earth, primed pump and sound went away and had great flow... If not, possible impeller problem..
Hayward... | Answered on Jul 15, 2011
let the air out of the filter as you try to start, this makes it hard for the pump to pick up the water. i would check the impeller and shaft seal,and basket for cracks, if the basket is cracked 99% of the time the impeller is plugged ..shaft seal there is is one one ebay with how 2 for around 10 bucks SMART ! PRIME the pump after a repair !!
Hayward... | Answered on Jun 07, 2011
You will have to change the power on your breaker ... take the white off and put it to the neutral bus. This will change the power beig delivered to the pump. In the motor, remove the white wire and put it on L1 ... black should already be on L1.
A side note ... 220 runs more efficiently and your motor will run cooler and at less expense. I suggest you not change it unless there is good reason.
Hayward... | Answered on Jun 05, 2010
Could the Error code be HS? That is high temperature limit. Perhaps you' don't have enough flow, allowing the heater to heat the water to a temperature higher, than the thermostat setting. Make sure your bypass valve is closed, allowing full flow through the heater. Check your filter pressure differential , and skimmer baskets.
You didn't give your model number, and there are many models. You can go the Hayward website below and select your exact model number and download the manual. The manual will explain each error code.
http://www.haywardnet.com/inground/products/manuals.cfm
Hayward Pool &... | Answered on Jun 07, 2020
remove insides of filter and replace fingers
Hayward Pool &... | Answered on Jun 01, 2020
clean or replace flame sensor but check burner tube below sensor for blockage
Hayward Pool &... | Answered on Dec 04, 2019
Are you sure it has a centrifugal switch?
Capacitor start/ capacitor run have been the standard for a good number of years.
Hayward Pool &... | Answered on Oct 26, 2019
Hayward's website has manuals for all their products.
check burn tubes for cobwebs or blockage
Hayward Pool &... | Answered on Sep 21, 2019
screw on impeller reverse threads and impeller unscrews normal thread hold back of motor shaft
Hayward Pool &... | Answered on Sep 15, 2019
The 24v is called the secondary and sometimes called the out-put. Make sure you have 240v on the primary, sometimes referred to as the in-put. If you have primary voltage then you should have secondary voltage, if not then replace transformer. Make sure the secondary, 24v control fuse is the correct size and present. If the secondary is shorting together or to ground somewhere, it will cause damage to the transformer.
Hayward Pool &... | Answered on Aug 18, 2019
Call a qualified electrician. More information would be needed to accurately trouble shoot your issue. Do you have automation connected to your heater? Is the heater trying to fire when the pump is off or is it ONLY the fan?
Try disconnecting your Water Pressure switch on the heater and see if the issue stops. With WP switch disconnected the heater should not work and the fan should stay off. Replace WP switch and see what happens.
Call a QUALIFIED electrician.
Hayward Pool &... | Answered on Aug 12, 2019
Hayward SP3015X20AZ 2 HP SUPER PUMP II  SP3015X20AZ Logo
4 questions posted
Top Hayward Pool & Spa Experts
Bill Jordan
john h
Marvin
Marvin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Hayward Pool & Spa
  • Hayward Pool & Spa
Most Popular Question
super ii pump 2 0 33 two
  • Pool & Spa
