20 Most Recent Pride Mobility Products Revo (3wheel) Questions & Answers
Pride scooters are known for this problem, as I found out when it happened to mine.
You need to replace the Throttle Pot. Either take it to a mobility shop and let them do it or buy the part and do it yourself. It simply involves unscrewing the old one and screwing the new one into place, and there are diagrams to help you on the internet.
This throttle pot problem has happened to my Pride scooter three times already.
Pride Mobility... | Answered on Aug 28, 2014
Have you checked that the freewheel lever is properly engaged? You will find it somewhere near the rear wheels. If it isn't engaged the scooter will not move when the power levers are pressed. It would react like a car in neutral ie nothing would happen.
Pride Mobility... | Answered on Aug 22, 2014
I know what the problem is as I have had it no less than 3 times with my own Revo. The Throttle Pot needs replacing. Luckily they aren't very expensive and you can fit it yourself if you are a handy sort of person. It just involves turning a screw to take out the old one and put in a new one. You can find diagrams on how to do it on the Internet. If you call a mobility company to come out and do it for you, they usually charge about £50 as a Call Out Fee.
The Revos seem prone to this throttle pot problem. Hope you get it fixed soon.
Pride Mobility... | Answered on Jun 21, 2011
MANY HAVE A BAR THAT WHEN THEY NEED PUSHED BY HAND IT DISENGAGES THE DRIVE .
Pride Mobility... | Answered on Mar 06, 2019
WELL POSSIBLY IF WE KNEW FOR WHAT BUT ALAS WE DO NOT
SORRY BUT WE (FIXYA) DO NOT SEARCH FOR PARTS .FOR ANY ONE . CALL YOUR LOCAL REPAIR SERVICE .
Pride Mobility... | Answered on Feb 15, 2019
From a pure physics standpoint...
The energy to climb a hill... be it from the steep side or the gentle sloping side is the same...
It is just easier on your heart and joints to take the gentle slope... (assuming you have the time).
ERGO:
If treating the scooter like a QUEEN
is your goal... DEFINITELY GO SLOW.
Tat way you will have no idea if it has any weak spots when you need it to go fast (and you will).
I'm old... I don't have TIME to waste!
Carnac the Magnificent
Pride Mobility... | Answered on Mar 28, 2017
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Pride Mobility... | Answered on Sep 03, 2016
Maybe too late for this advice but it is important to take a detailed photograph of the wireing before unplugging anything.
Pride Mobility... | Answered on Jul 02, 2016
I'd recommend a dental pick.
Pride Mobility... | Answered on Jun 01, 2016
Hi not much info is there a red LED & green LED on charger...or is there a red LED & orange led on ?? Bit more info would help cheers
Pride Mobility... | Answered on May 16, 2016
Hi check the main circuit breaker c photo push the white button in to c if it has tripped open cheers
Yes a technician with a programmer can set the control very slow so it is limited on how fast it can go. Otherwise the joystick is meant to be adjustable, so setting it to one speed only not possible.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Pride Mobility... | Answered on May 15, 2016
hi Linda, can you please tell me what model pride this is ?
Regards
Rob
Pride Mobility... | Answered on Dec 05, 2015
Candy Apple paint is extremely hard to patch repair. It has a base coat of silver or gold and then multi coats of the candy apple over the top.
You can get a paint that is meant to be a touch up for candy apple but you never end up with the same shade of color. Most of the time it will come out dark blood red anywhere that it over laps the old paint.
I would contact Pride as they may use a paint that does not require a base coat.
Pride Mobility... | Answered on Oct 27, 2015
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
Pride Mobility... | Answered on Aug 03, 2015
Pride Mobility Products Revo (3wheel) Logo
5 questions posted
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Mobility Products Health & Beauty
Most Popular Question
scooter will not move batteries charger
  • Health & Beauty
