20 Most Recent
Pride Mobility Products Pride Victory 9 PS 3Wheel Mobility Scooter Red Questions & Answers
Power not going to solenide
hi, you need to check where the rear axle comes away from the main frame , the connections here are known to create problems,
Can you hear the brake unit clicking ?
remove the wheel, then remove the brake unit normally fixed by three phillip screws ,please take care not to damage the heads , now disconnect the brake unit but not the wiring, power on and move the throttle lever , does the motor turn ? then it's your brake unit that faulty or the wiring leading to it so check that out, in rare cases the controller has created a fault therefore not powering the brake so the motor cannot turn.
Motor still does not turn, then it either the output stage of the controller that's faulty or the motor itself which again is rare.
Please leave feedback if the advice helps.
Regards
GeWiz.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
