20 Most Recent
Invacare Supply Group Invacare Lynx L3 3Wheel Travel Scooter Blue Questions & Answers
No display, won't charge, dead, after cold storage
hi, you say the voltage is 3 volts each, then it never work , remember it's requires at least 18 to 20 volts to light up.
if a battery measure's below 10v it's normally impossible to charge again as a lot of chargers will not go below this level, you could try a car battery charger to bring the level up however do this with care and don't leave on charge
Regardswww.gewizrepairs.co.uk
Invacare Supply...
Answered
on Dec 28, 2012
Lynx l3 dead
hi, Are you sure then battery box is fitted correctly ? you need to make sure the battery box is supplying a voltage to the scooter, there is a fuse located within the box however it rare to blow this unless you used a higher amp charger , normally more than 5 amps, this type of charger would be for a 8 mph scooter etc.
IF you have access to a electrical meter plug the two probes into the outside pins of the charger socket , do not allow them to touch, measure the voltage, no voltage then the fuse has gone or a contact has come off the battery
IF you located anywhere near me SS16 then testing is free.
Regards
Invacare Supply...
Answered
on Dec 28, 2012
Battery discharges after 1 block. They are new
Did you charge the batteries before you used them? if not you need to charge overnite to build up a good charge. If after an overnite charge you are showing full charge but you still get poor performance then you need to return the batteries for new ones. Remember just because they said they are new doesn't mean good They could have sat on the shelf for 6 months or more. Hope this helps
Invacare Supply...
Answered
on Mar 30, 2011
What flash codes mean
They are diagnostic codes to help troubleshoot a possible problem with your wheelchair. The lights blink in patterns. You have to count the number of blinks and what color they are.
Invacare Supply...
Answered
on Jun 25, 2015
24v dc motors can it run at all with 12vdc
Sure. Just slower.
If you remove the motor from a power wheelchair to use in other applications keep this in mind; these motors are designed for PulseWidthModulation Speed Control (apx. 10kHz) with a feedback control to keep the speed more consistent. Feedback and pulsing is key to power and efficiency. If you run them at 12 volts without a pulse control the current to power output is much higher and the I*I*R (I squared times R) losses are higher - dissipated as heat. The motors will run very hot under a load with DC that isnt PWM'ed.
If the use/cool down duration is short you should not have issues.
Invacare Supply...
Answered
on May 13, 2014
Is it possible to reverse the drive lever on the
Hi Mark.
Reversing the polarity:There are 3 wires on the Wig Wag Assembly. (reverse the wig-wag function) simply de-solder the 2 outer wires & swap their position & re-solder.I would seek a price for doing the job from an approved scooter repairer,unless you are comfortable doing the job yourself.I hope this has helped,Colin
Invacare Supply...
Answered
on Dec 28, 2013
Wiring
most manufacturers will NOT supply you with that, very difficult to get, FDA has strict guidelines on who can repair and maintain power chairs. what is the problem with the chair
Invacare Supply...
Answered
on Sep 05, 2012
