20 Most Recent Pride Mobility Products GoGo Elite Traveller 4 Wheel Travel Scooter Questions & Answers
this could mean the scooter is not in drive try the free wheel lever first.
Pride Mobility... | Answered on Feb 14, 2019
You will need to unscrew the tiller cover and remove the throttle pot. The lever itself will need the allen screws loosened. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Pride Mobility... | Answered on Jun 01, 2016
hi , have you checked the charger ? try another charger if possible, how old are the batteries and how long have they been left without charging ?
Regards
Rob
www.gewizrepairs.co.uk
Pride Mobility... | Answered on Jul 22, 2015
If the light is solid then everything is fine if its flashing it is showing a fault.
Pride Mobility... | Answered on May 09, 2015
Is the scooter in free wheel or drive
hi, how many bleeps before a pause ? or is it constant bleeping ?
This error can be caused by a bad connection , check where the back end comes away from the frame...
Regards
Rob
Pride Mobility... | Answered on Apr 18, 2015
Find the buzzer and disconnect wires from there, or cut one or both of the wires at the buzzer and tape the connection to prevent shorting.
Pride Mobility... | Answered on Apr 09, 2015
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Pride Mobility... | Answered on Feb 16, 2015
the charging fuse on these is internal inside the battery box
1 carry out a continuity test in this blade fuse for open circuit
2 while open check battery volts is over 11 volt or scooter will drive=o/k if lower will need batteries replaced.
3.make sure your charger is the correct one for this scooter
as go go chargers conector are wired different .so a standard mobility charger wont charge these,as there will be no 24volt at pins 1 and 3 ,
Pride Mobility... | Answered on Jan 16, 2015
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Pride Mobility... | Answered on Jan 04, 2015
Try and gently rock your scooter backwards and forwards as you are trying to move the lever this can help. spray a little wd40 on where the lever connects to the motor. If this doesn't help then the electric brake has ceased and needs an engineer to sort.
This is probably due to "static" electricity discharging from the rider to earth via the person who touched you. Static is often caused by the clothes you wear (especially man made fabrics like nylon). Try fitting a discharge strip ( like you see on the back of cars) to the scooter or change the type of chothing you wear (wool or cotton does not cause static to build up)
Pride Mobility... | Answered on Dec 03, 2014
Is the drive key on the axle there?
Pride Mobility... | Answered on Nov 23, 2014
hi, it's it's running okay but bleeping , could be low battery voltage or a failure in the bleeping circuit with wiring or the controller...
Regards
Rob
www.gewzirepairs.co.uk
Pride Mobility... | Answered on Aug 17, 2014
hi, the 5 bleeps are related to the brake,,, located at the rear of the scooter located on the side of the motor, attached to that is the free wheel lever,, in drive mode ,, check that the microswitch is working correctly, check the wire( connectors etc ) from the brake to the controller ,
www.facebook.com/gewizrepairs
Pride Mobility... | Answered on Aug 07, 2014
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Pride Mobility... | Answered on Aug 05, 2014
hi , That an be caused by a bad connection to the controller , refit sockets on the PG Drives controller.... this can also be a controller fault...
I offer free testing ...you only pay the return postage...
Regards
Rob
Pride Mobility... | Answered on Jul 19, 2014
Pride Mobility Products GoGo Elite Traveller 4 Wheel Travel Scooter Logo
52 questions posted
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Mobility Products Health & Beauty
Most Popular Question
gogo elite traveller wont chrage
  • Health & Beauty
