20 Most Recent
Electric Mobility Merits Pioneer 3 Hd Scooter S131 () Questions & Answers
My dad has a merits 4 wheel pioneer that flashes 5 times
what fault code is this
This flash error code for the dynamic controller indicates a park brake fault. Try moving the brake lever back and forth in each direction to clear the fault. You may have a faulty brake or brake microswitch. You can test the brake with a voltmeter. It should read 40 to 60 ohms and not shorted or open. You can test the microswitch by pushing it and checking for switch closure using a voltmeter. You need to turn the scooter on and off to clear the last fault. Hope this helps.
Electric...
Answered
on Mar 09, 2016
I have a merits s131
Put the unit in drive mode (engage the brake) and try again. If one way doesnt work, try the other way. If this doesnt work you may have a faulty brake switch or brake wiring. Replace both and try again.
Electric...
Answered
on Aug 11, 2014
Battery shows charged, meter shows green but the
MKane I'm sure you checked the freewheel lever located under the right rear shroud to make sure it wasn't in freewheel. If its in drive mode are you hearing the brake click when you push in the throttle? Scooters are hard to troubleshoot because of all the different components used to make it go. It could be the throttle pot, the speed control pot, the cable going from the console to the rear of the scooter. Check the circuit breaker or fuse at the rear to make sure it hasn't popped. Check all your connectors at the rear to make sure none has come loose. Without being there this is the best I can do for you. You might contact your Provider where you got the scooter to see if they will check it for you Good Luck Hope this helps you
Electric...
Answered
on Oct 27, 2010
Wigwag Throttle Control Pot FREERIDER loose
The spring that applies tension on the wigwag often breaks. After removing the shroud to gain access to the throttle, back off the two allen screws (2mm) and pull off the throttle handles, remove the nut in order to replace the spring. The cost of the spring is about $4.00 compared to the complete throttle at about $250.00.
Electric...
Answered
on Mar 25, 2019
