20 Most Recent
Seca 869 Medical Platform Scales Questions & Answers
I've pulled the connecting cable out
You need the cable to be correctly fitted inside the scales base, open up the case of the base and have a good look at how the cable connects to it, see if you can reconnect it.
What does code E 11.60 means on seca scale model 799
Try a simple reset first. Turn the scales Off, remove the batteries and unplug it from the wall power source if it has one. Do not do anything to the scales for 5 minutes. Refit (or replace) the batteries and plug it back into the wall power outlet if it is using one. Turn the scale back on. This should clear the error code. If the code comes back you will need a repairer to look at it as it could be a problem with the parts inside the scale.
Error code 10.12 on Seca Scale 769 meaning
Error code 10.12 on Seca Scale 769 indicates a communication error between the scale and the connected device. This could be due to a loose connection, incorrect settings, or malfunctioning components. It is recommended to check all connections and settings, and if the issue persists, contact the manufacturer for assistance.
Error code 10.11 on Seca Scale 769 meaning
Error code 10.11 on a Seca Scale 769 indicates an internal error with the device's microprocessor. This may require the scale to be serviced or replaced. It is recommended to contact the manufacturer for assistance in resolving the issue.
How many protein bars should I eat per day?
Go with whole food proteins or quality whey shake. Make sure you know what you are eating, Cliff is probably one of the highest rated ones, so two bars would be fine along with normal meals. Whey protein is a naturally complete protein, meaning that it contains all of the essential amino acids required in the daily diet.
Whey protein is a rich source of branched chain amino acids (BCAAs), containing the highest known levels of any natural food source. BCAAs are important for athletes since unlike the other essential amino acids, they are metabolized directly into muscle tissue and are the first ones used during periods of exercise and resistance training.
Whey protein provides the body with BCAAs to replenish depleted levels and start repairing and rebuilding lean muscle tissue.
How often should I visit my dentist?
Most adult and children visit the dentist for regular
checkups and cleanings every six months. People at greater risk should have
checkups more often.
Charger not working plug in light stays green, but battery is not charged
I have got 3 different chargers for my scooter. It's a Tifgalop T108. The charger light would stay green on the new chargers. My old one was the only one that was charging it. While I was replacing the charging ports, I came to find out that the negative wire is in a different location on the new ports. The negative wire was on number 3 on the old ones and is in number 2 on the new ones. After changing the ports all my new chargers work fine now.
