20 Most Recent Mi T M MiTM GEN40000MH0 4000 Watt 8 HP Honda OHV Portable Gasoline Generator Questions & Answers
unless you are a master electrician this becomes very complicated. First you need a generator that is large enough to power everything in your house, then you need a auto power up system
Guide to Buying Standby Generator
Mi T M... | Answered on Aug 04, 2015
output depends on what loads you draw on any genset
Electrical... | Answered 2 days ago
power to starter have never seen one to know if they have a solenoid for it or not
Electrical... | Answered 3 days ago
you have carb passages that are still clogged up. when you do get it all clean and running always use a little seafoam in your fuel. it works very well on small engined units... a few ozs in 5 gallons is plenty and stores very well also.
Electrical... | Answered on Jun 12, 2020
check the operation of the oil level sensor . No oil no start
Electrical... | Answered on Jun 08, 2020
From what I see on other disposals, the hex is in the middle of the bottom. Remove the paper tag.
https://www.youtube.com/watch?v=J0OByRuoYM0
Electrical... | Answered on Jun 06, 2020
You could always use "Belt Ease" from an Auto Parts store. It's made for squeeky belts.
-Lonnie
Electrical... | Answered on Jun 03, 2020
The generator does not operate in accordance with the specified technical conditions, such as too high stator voltage, iron loss increases; if the load current is too large, the copper loss of the stator winding increases; if the frequency is too low, the cooling fan speed becomes slow, affecting the heat dissipation of generator; the power factor is too low, so that the rotor excitation current increases, resulting in the rotor heating. Check whether the indication of monitoring instrument is normal. If it is abnormal, necessary adjustment and treatment must be carried out to operate the generator in accordance with the specified technical conditions.
www.dieselgeneratortech.com
Electrical... | Answered on May 29, 2020
Exhaust black smoke
The main causes of exhaust pipe blackening are less air in the cylinder, more fuel, incomplete or untimely combustion of fuel. Therefore, when checking and analyzing faults, look closely around this point to find out reasons. Check cylinder by using the method of oil cut, the first distinction is that the individual cylinder is not working well or all cylinders are not working well. If the black smoke disappears when a cylinder stops working, then the black smoke is caused by the bad work of individual cylinders. The reasons can be found from the bad work of individual cylinders.
The main reasons are:
A. Poor nozzle operation
The injection pressure of the injector is too low, the nozzle drips oil, the spray quality is not good and the oil droplet is too strong, all of which will cause the diesel fuel to burn incompletely. Therefore, in the detection of diesel engine cylinder knocking sound, exhaust sound uneven, that is, fuel injection problems, should be immediately checked and adjusted injection nozzle.
B. The fuel injection pump adjusts the tooth rod or the adjustment rod stroke is too large, resulting in too much fuel supply.
C. Valve clearance does not meet requirements, resulting in insufficient air intake.
D. The contact surface between the plunger sleeve of the injection pump and the valve seat is not sealed, or the locking screw of the regulating ring of the fuel injection pump or the loosening of the plunger adjusting arm cause the imbalance of the fuel supply and lead to intermittent black smoke emission.
More supports, please see on www.dieselgeneratortech.com
Do normal maintenance first, like oil, oil filter and air filter and then let it firts warm up before applying a load.
You have posed a very vague question with no details about the application and have even omitted to tell us whether you have a generator set or whether you have the alternator and wish to build your own generator set?
In the case of a generator set the requirements and precautions will be found in the owner's instruction handbook.
Hello, friend, you can check the user manual or ask the supplier who provide the genset to you.
Electrical... | Answered on May 25, 2020
Hi there!
Take a look at pic 2 and pic 6 on this page.
The colors do not matter there is no forced set standard for wiring and colors but we are aware of commonly used color schemes.
Pole 2=Line
Pole 3= High
Pole 4=Low
Ground is Ground
https://www.spapumpsandmore.com/spa_pump_motor_2_speed_Century_BN50_115v_16_4a_p/mtraos-15115.htm
Good Luck!
Mr.Mike
Electrical... | Answered on May 20, 2020
Removing a circuit breaker from your home's electrical service panel is an easy job that takes just a few minutes. However, it's not a suitable project for homeowners who are unfamiliar with electrical systems. The service panel is where the utility's power comes into your house, and portions of it carry deadly levels of electricity at all times. Removing the panel cover exposes the live elements, so you must be very careful not to touch them.
Instructions
  1. Turn Off the Main Breaker. Make sure the ground or floor and the electrical service panel are completely dry. ...
  2. Unscrew the Panel Cover. ...
  3. Remove the Cover. ...
  4. Test for Power. ...
  5. Turn Off the Branch Breaker. ...
  6. Rock the Breaker Back. ...
  7. Pull the Breaker Out. ...
  8. Unscrew the Breaker Wire.
Electrical... | Answered on May 13, 2020
Mi T M MiTM GEN40000MH0 4000 Watt 8 HP Honda OHV Portable Gasoline Generator Logo
1 questions posted
Top Mi T M Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Mi T M Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Mi T M Electrical Supplies
Most Popular Question
starts switch fine but when let go
  • Electrical Supplies
