20 Most Recent Mastech MS8902A 600V Noncontact AC Voltage Detector Questions & Answers
0answers
0answers
0answers
Where canI find a printout
The red light means you are near a Hot (Black), or any hot wire or outlet. Remember, on this kind of tester, it is only to know if you have power in the circuit. It will not register on the common (white) wire, or green ground.
I am attempting to upload the owners manual for you. Good luck! & Thank you for using Fix Ya.jrsizer.jpg
7/22/2011 2:15:36 PM • Mastech MS8902A... • Answered on Jul 22, 2011
HOW TO USE THIS PRODUCT.
The green light flashes when you turn on the unit, or adjust the sensitivity. Hold the front arrow to increase the sensitivity. Hold the rear arrow to decrease the sensitivity. The unit only senses the hot (black) wire. To test the ground or common, you will need a contace tester, not this non contact tester. Set the new default by adjusting the sensitivity on a known good outlet. When you have reached your desired default sensitivity, press and hold both arrows at the same time for two seconds. The new default sensitivity is now set, and will return to that point every time you turn the unit off, then on again.
This unit is designed to only let you know if you are handling a live wire or not.
7/8/2011 5:52:01 AM • Mastech MS8902A... • Answered on Jul 08, 2011
Instructions on how to use
+ is positive
- is negative
6/28/2011 12:01:48 AM • Mastech MS8902A... • Answered on Jun 28, 2011
Ano ang kahulugan ng multitester
jxsfj kndbv kjzdbvjk
12/23/2016 11:07:23 PM • Mastech... • Answered on Dec 23, 2016
I want to have shematic diagram multimeter Mastech mod. MS8222H. I want to calibrate my multimeter.
https://www.youtube.com/watch?v=dk1ifG9ezAs
12/23/2016 10:48:19 PM • Mastech... • Answered on Dec 23, 2016
0answers
Need Mastech Sinometer MS8230B instruction manual
i've just uploaded the pdf manual but it's useless, just gives spec. and i was looking for what the 'H' button was for...
1/26/2015 4:37:07 PM • Mastech... • Answered on Jan 26, 2015
0answers
0answers
10 Mhz output is incorrect
output on what?
10/15/2013 1:59:41 AM • Mastech... • Answered on Oct 15, 2013
Rf tech 433mhz manual model 217S31
I want to use an old sensor forgiven during 30 years. I have no more manual, off course. Thanks for your answer
3/26/2024 11:42:40 PM • Measuring Tools... • Answered on Mar 26, 2024
What are the readings on a meoisture meter measured in?
Most moisture meters measure the moisture content of wood or concrete is measured in percentages. So if the reading says 15 that means that there is a content of 15% moisture in the concrete.
3/16/2024 7:34:55 AM • Measuring Tools... • Answered on Mar 16, 2024
Mastech MS8902A 600V Noncontact AC Voltage Detector Logo
Popular Tags
10 questions posted
Top Mastech Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Mastech Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Mastech Measuring Tools & Sensors
Most Popular Question
use product
  • Measuring Tools & Sensors
