20 Most Recent
Kwikset 907 L03 Smt Cp Powerbolt Questions & Answers
I Have a new Kwikset 909 LO3 SMT CP unit - How do I change door handedness?
In section 8 of your instructions is the "Door handing" programming instructions Link here: http://s7d5.scene7.com/is/content/BDHHI/Website%20Content/Kwikset/Resources/KwiksetSmartCodeManual.pdfYou need to carefully go through this programming routine without interruption. That should fix it for you. Good luck!
I need a new touch pad there is a break in the
I could not find individual parts listed on their web site: http://www.kwikset.com/Customer-Support/Overview.aspx
So I suggest that you contact them directly for replacement parts. Here's their contact information:
You can call 1-800-327-LOCK (5625) and a
Consumer Service Representative will be more than happy to assist you,
or you can write to us at this address:
Kwikset Consumer Service
19701 DaVinci
Lake Forest, CA92610
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.)
The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
