20 Most Recent Kwikset 4 Lido Lh Passage Levers Satin Chrome 200ll 26d Questions & Answers
wrong access code, ace.
Kwikset 4 Lido... | Answered on Dec 30, 2014
You will need an allen (hex) wrench to loosen the setscrew that holds the lever. Once loosened, it pulls off easily.
Kwikset 4 Lido... | Answered on Jun 24, 2014
Sure, let me give you a link to the installation instructions for the Kwikset Lido(keyed lock):
http://s7d5.scene7.com/is/content/BDHHI/44593-01
If this is not what you had in mind, go to this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Levers_Lido
and select the model most like yours. Clicking on the picture will bring up installation and warranty links, etc.
Please note that if I haven't been able to help you, then I urge you to contact Kwikset Customer Support:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Kwikset 4 Lido... | Answered on Oct 03, 2012
I'm not sure whether you need instructions for an entry door or an internal bedroom or closet door. So let me steer you to the online site:
Go to :
http://www.kwikset.com/Products/Categories/Door-Levers.aspx
Then "Browse by function" for the appropriate type, then choose the Lido
On the next page, you can click on any Lido finish, the instructions will be the same regardless of finish.
Once you 're on the next page, under the red "Technical Documents" heading, choose "Installation Guide".
It will take a moment to download the PDF file of the installation instructions for you to follow.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Kwikset 4 Lido... | Answered on Aug 04, 2012
Yow will need to do some investigative disassembly and reassembly to spot the problem.
Here is a link to the installation instructions for your lock (in five languages!) to assist your operation:
And here is the link to Kwikset's lifetime warranty against mechanical defects, wherein you will find the contact number to call them for further customer assistance and parts replacement:
http://s7d5.scene7.com/is/content/BDHHI/warranty2009
Or, if you wish, call them before you disassemble your lockset.
Good luck--and please provide feedback if this helps!
Kwikset 4 Lido... | Answered on Dec 11, 2011
Advanced product search:
http://www.kwikset.com/Products/Advanced-Product-Search.aspx
customer service http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Kwikset 4 Lido... | Answered on Nov 06, 2011
The short answer is that you can't get the doorknob off from the outside.
Lock sets and door knobs are purposely made that way to thwart any potential thief with a screwdriver from simply removing the door knob to gain access into our homes and rooms.
What you MAY TRY is to carefully pry loose the door trim in the area of the door knob away from the door jamb. You may have to carefully remove a trim nail in the process.
Then experiment with a flat, thin, solid tool like one of those rounded spatulas used for frosting cakes slipped in between the trim piece and the jamb. Your goal is to try to get the spring latch to retract away from the door's strike plate like James Bond with a credit card. Look at one of your other open doors to visualize how the mechanism works.
This is going to require some patience, but it may save you from having to destroy the door or frame to get into the room.
Kwikset 4 Lido... | Answered on Jul 27, 2011
Re-categorize your question please
Kwikset 4 Lido... | Answered on May 13, 2011
Stick a sturdy pin in the hole and at the same time pull on the lever. this should remove the lever , then you can remove the plate to get at the screws.
Hope this helps
Kwikset 4 Lido... | Answered on May 11, 2011
I'm including a link to the installation/assembly instructions for the Lido LL730 3:
http://s7d5.scene7.com/is/content/BDHHI/44594-01
I'd recommend that you contact Kwikset Customer Support if you are unable to repair it:
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Here's the link for their customer service page:
Kwikset 4 Lido... | Answered on Mar 10, 2011
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Kwikset 4 Lido... | Answered on Mar 06, 2011
when you say "removing all hardware" do you mean,All hardware such as hinge pins and or hinges to get the door off?
Kwikset 4 Lido... | Answered on Oct 15, 2010
it will not work without the original key.
can you pull the hinge pins so you can remove the door. if so that will make it easier to work on
Kwikset 4  Lido Lh Passage Levers Satin Chrome 200ll 26d Logo
23 questions posted
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Kwikset Locks & Locksmithing
Most Popular Question
one front door
  • Locks & Locksmithing
