20 Most Recent Weiser Lock GED1460X3BR Lifetime Polished Brass PowerBolt Powerbolt Touchpa Questions & Answers
How do I replace batteries in weiser keysless lock?
Not sure on a Weiser but on mine there are small Allen screws on each side of the cover that have to be removed that allow the cover to be removed.
1/31/2015 10:44:48 PM • Weiser Lock... • Answered on Jan 31, 2015
0answers
Weiser lock diagram
The installation instructions:http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdfA note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:http://get.adobe.com/reader/
9/10/2012 12:08:30 AM • Weiser Lock... • Answered on Sep 10, 2012
Lost set screw on door knob
At any hardware store. take the threaded part with you to get the right one.
4/12/2012 4:23:58 PM • Weiser Lock... • Answered on Apr 12, 2012
How do I turn the
Weiser has a one year warranty against electronic problems and a lifetime warranty for mechanical and finish problems with their locks. Contact them from this link: http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx Good luck!
11/6/2011 10:18:04 PM • Weiser Lock... • Answered on Nov 06, 2011
How to remove the back
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspxNotice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
11/6/2011 9:58:40 PM • Weiser Lock... • Answered on Nov 06, 2011
I need to reset the code
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
6/23/2011 12:51:24 AM • Weiser Lock... • Answered on Jun 23, 2011
How do you reprogram after battery has died?
Here's a link which tells you how to remove the cover, and reprogram the lock codes:http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
3/5/2011 10:19:21 PM • Weiser Lock... • Answered on Mar 05, 2011
We lost the directions how do you change the code
3/5/2011 9:48:51 PM • Weiser Lock... • Answered on Mar 05, 2011
When i unlock my door , it locks & unlocks
Try this:
Here is a link to the Frequently asked question page for your lock:
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
3/5/2011 9:45:28 PM • Weiser Lock... • Answered on Mar 05, 2011
How do I reset code on this lock
see this page - http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
12/26/2010 4:41:49 PM • Weiser Lock... • Answered on Dec 26, 2010
When lock button is pushed,
Sounds like the lock was instaled wrong. If the lock has been there for some time then the lock has gon bad and needs to be replaced.
Good Luck
12/1/2010 4:21:40 PM • Weiser Lock... • Answered on Dec 01, 2010
What is the Model number of my WEISER lock set? Purchased in 2004.
not enough information photos may help but might be faster to buy new lock be safe
6/8/2019 12:17:40 AM • Weiser Lock... • Answered on Jun 08, 2019
How to remove battery cover on older weiser lock
3/20/2019 7:17:17 AM • Weiser Lock... • Answered on Mar 20, 2019
I installed a new weiser keylesslock, it works fine a about 1 month. But now 2 button do not work. Other button works fine. I opened it, the wire is tight, the batteries were new. What could be wrong?
I'd try a new battery to "rule out" that as a problem, sometimes the contacts need a "turn" of the battery to make good contact.
2/11/2018 1:57:46 PM • Weiser Lock... • Answered on Feb 11, 2018
0answers
Weiser Lock GED1460X3BR Lifetime Polished Brass PowerBolt Powerbolt Touchpa Logo
17 questions posted
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Weiser Lock Locks & Locksmithing
Most Popular Question
need reset code
  • Locks & Locksmithing
