20 Most Recent Weiser Lock GED1460X GED1460X3BR Lifetime Polished Brass PowerBolt Powerbol Questions & Answers
0answers
How do i change the code?
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspxNotice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
11/6/2011 10:00:43 PM • Weiser Lock... • Answered on Nov 06, 2011
How do i delete old access code and enter new
Here's the link that you need:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
I'd recommend changing the batteries at the same time that you are reprogramming the lock if it's bee a while.
7/9/2011 10:01:51 PM • Weiser Lock... • Answered on Jul 09, 2011
Keeps beeping after installing new
Here's the link to the troubleshooting procedure for the Powerbolt, wherein beeping is discussed:
If this doesn't help, I recommend contacting their Customer Support for further advice and parts:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
5/9/2011 1:02:12 AM • Weiser Lock... • Answered on May 09, 2011
Partial draw back of bolt on the 1st attempt with
I understand that you've already checked for any mechanical binding within the lock and between the lock and the strike plate--(does this problem occur when the lock is cycled when the door is open?)
I'm including a link to the troubleshooting page for your powerbolt:
If you don't find a solution here, although the lock is beyond its one year warranty, I'd still contact Weiser Customer Service (preferably by phone) and appeal to them to help you troubleshoot or replace your lock. Here's the contact information:
5/9/2011 12:58:31 AM • Weiser Lock... • Answered on May 09, 2011
I just purchased a home with one of these types of
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
4/26/2011 5:35:04 PM • Weiser Lock... • Answered on Apr 26, 2011
We,ve never been able to get it to work and my
Let me assume that you've already installed the Powerbolt 1000 (the one that matches the picture!), so let me link you to the Troubleshooting instructions, which illustrates how to open and reprogram the lock:
Please install fresh batteries at this time.
Also please take a look at this link,
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
which tells you how to locate and change the jumper to set the lock up for a door which is "right-handed" or "left handed"-in other words, what side the door hinges are on as you face it from the exterior. If the jumper is set wrong, the lock will not function properly.
Lastly, here's a link to the Weiser cutomer Support contact page:
4/26/2011 5:06:51 PM • Weiser Lock... • Answered on Apr 26, 2011
Changing the unlock code.
3/5/2011 10:48:38 PM • Weiser Lock... • Answered on Mar 05, 2011
How do you remove your old lock codes and
See this website for more info - http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
12/26/2010 4:38:12 PM • Weiser Lock... • Answered on Dec 26, 2010
What is the Model number of my WEISER lock set? Purchased in 2004.
not enough information photos may help but might be faster to buy new lock be safe
6/8/2019 12:17:40 AM • Weiser Lock... • Answered on Jun 08, 2019
How to remove battery cover on older weiser lock
3/20/2019 7:17:17 AM • Weiser Lock... • Answered on Mar 20, 2019
I installed a new weiser keylesslock, it works fine a about 1 month. But now 2 button do not work. Other button works fine. I opened it, the wire is tight, the batteries were new. What could be wrong?
I'd try a new battery to "rule out" that as a problem, sometimes the contacts need a "turn" of the battery to make good contact.
2/11/2018 1:57:46 PM • Weiser Lock... • Answered on Feb 11, 2018
0answers
Weiser Lock GED1460X  GED1460X3BR Lifetime Polished Brass PowerBolt Powerbol Logo
Popular Tags
13 questions posted
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Weiser Lock Locks & Locksmithing
Most Popular Question
change code
  • Locks & Locksmithing
