20 Most Recent Kwikset 907 90715 Satin Nickel SmartCode Smart Code Deadbolt with One Touc Questions & Answers
You may wish to go through the installation programming routine again (make sure that the batteries are fresh)
Here's the link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Programming instructions are found on Page 6.
If that fails, the lock is covered by warranty and the contact information is on the instruction sheet.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader if the file will not display for you.
Good luck--and please provide feedback if this helps!
Kwikset 907 ... | Answered on Nov 05, 2011
I have reviewed the on-line installation instructions for this lock, and it requires attention to detail to properly install.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For instance, the first one may have not closed all the way if your door has a 2 3/4" setback instead of 2 3/8", and you did not extend the bolt and adjust the latch as shown in figure 2 of Step 1.
Also, if you don't run the door handling routine properly as in Section 8, the lock won't work properly.
But I believe that you are past that learning curve after the second installation, and I don't know why the backlight won't work on your new lock.
I didn't see any option to enable/disable it in the instructions. So my suggestion: If the lock is otherwise working properly such that the backlighting is the only problem, I'd give a call to the Customer Service number 1-800-677-5625 and discuss it with them. They will let you know if and what the problem is, and a new lock is certainly under warranty!
Kwikset 907 ... | Answered on Jul 23, 2011
I don't know if this is the best answer, but I would try to slip a heavy credit card between the door and the jam where the knob is. It may be a quick solution for the moment.
Kwikset Locks &... | Answered on Jun 25, 2019
Have you released the knobs? They are held on with a small depression thing on the stem of the handle. Press this in and pull on the knob to release it.
Try the video it may be of some help but do the opposite
to the fitting.
Kwikset Locks &... | Answered on Jun 13, 2019
notify manufacturer or locksmith
Kwikset Locks &... | Answered on May 02, 2019
Remove it and take it to a locksmith or
go get a new one or
hire a locksmith to come out to your house
they have tools to be able to reset when you have no working keys
Kwikset Locks &... | Answered on Mar 23, 2019
It could be that you are trying to add a code again as well. You can not have the same code in say space one that you have in space 5.
My Kwikset lock has been working beautifully for several years now, and it is handy to not have to use keys.
If you can't figure out the programming, and want to start from scratch, with mine I believe that you remove the battery pack, press in on the program button for ten seconds, and reinsert the battery pack while still holding the program button. That erases all of the stored codes, and you can start over again.
None of what you described sounds like a locking issue, but a programming issue.
Kwikset Locks &... | Answered on Mar 07, 2019
Kwikset 907  90715 Satin Nickel SmartCode Smart Code Deadbolt with One Touc Logo
3 questions posted
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Kwikset Locks & Locksmithing
Most Popular Question
just completed installing
  • Locks & Locksmithing
