20 Most Recent Weiser Lock GED1460X GED1460X15A Antique Nickel PowerBolt Powerbolt Touchpa Questions & Answers
I recommend that you got to this link:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
and contact Weiser Lock for technical assistance. Yours is an uncommon problem.
Weiser Lock... | Answered on Nov 05, 2011
This link will take you to the installation & programming instructions (on page 6) for the Kwikset Powerbolt, which is exactly the same as the Weiser Powerbolt:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Weiser Lock... | Answered on Jul 31, 2011
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Weiser Lock... | Answered on Jun 27, 2011
Your best bet is to contact Weiser Lock directly. Here is a link to the contact information that you need:
Weiser Lock... | Answered on Mar 06, 2011
not enough information
photos may help but might be faster to buy new lock
be safe
Weiser Lock... | Answered on Jun 08, 2019
Recut from another key.
If no keys, a locksmith will put in a new cylinder in with a set of three matching keys. My whole hotel in the UK was fitted with Weiser locks.
See the link
weiser lock cylinder replacement Google Search
Weiser Lock... | Answered on Feb 21, 2018
I'd try a new battery to "rule out" that as a problem, sometimes the contacts need a "turn" of the battery to make good contact.
Weiser Lock... | Answered on Feb 11, 2018
Brent, Try resetting initialization/ installation or contact weiser. Attached you will find links to your manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.weiserlock.com/pdfs/instructions/electronics/smartcode.pdf
http://www.weiserlock.com/PDFs/instructions/Electronics/5062000-Powerbolt2-Instructions-eng.pdf
http://www.weiserlock.com/en/customerservice/productsupport/supportcontact.aspx
Weiser Lock... | Answered on May 27, 2016
[PDF]Quick Reference Installation & Programming Manual
www.weiserlock.com/.../electronics/smart...
Translate this page Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Weiser Lock... | Answered on Nov 26, 2015
2 important things which may seem dumb but solved my problem:
- Make sure that once everything is in place, you hold the lock button before inserting battery pack (and keep holding the lock button) until you hear 2 beeps. The latch should come and go.
- Last but not least, make sure you put NEW batteries in... I had old batteries and when i tried it seemed like is was working but could not finish the door direction finding sequence stated above. Make sure they are new and it should work!
Weiser Lock... | Answered on Jul 21, 2015
I have the Weiser Lock powerbolt 3000 Home Access system Model WLTX Garage door opener and the Battery is a Maxell CR2032 3 Volt. very common.
Weiser Lock... | Answered on Feb 14, 2015
If you mean it feels like it's dragging when extended, it probably need to the screws holding the inside portion of the lock to the outside portion and realign those two while actuating the lock to find where it operates freely.
Weiser Lock... | Answered on Jan 31, 2015
Look up model and go to website, they are all different
Weiser Lock... | Answered on Aug 23, 2014
Weiser Lock GED1460X  GED1460X15A Antique Nickel PowerBolt Powerbolt Touchpa Logo
6 questions posted
Top Weiser Lock Locks & Locksmithing Experts
Scoee Scoffer
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Weiser Lock Locks & Locksmithing
Most Popular Question
lock least 5 yars
  • Locks & Locksmithing
