20 Most Recent Jasco GE 06685 24Hour Mechanical Timer Switch White Questions & Answers
Timer does not move with the time of day
Copy following link to identify timer.http://waterheatertimer.org/Woods-timers-and-manuals.html#59017Copy following link to see how to wire single-pole timers.http://waterheatertimer.org/How-to-wire-timers.htmlAdd a comment and describe the timer, and include if this is new timer or older timer that stopped working, and include what you have tried so far. If fixya sends email, then I can followup with more information. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2013 8:39:39 PM • Jasco GE 06685... • Answered on Jul 19, 2013
I have connected the Black
I have extensive files on timers and don't recognize that GE number.
Possibly you have GE 15071 or 70 or similar timer.
Open following link to identify timer, and read step-by-step wiring.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
3/8/2011 10:27:30 PM • Jasco GE 06685... • Answered on Mar 08, 2011
Lost instructions to program a 7 day programmable
GE timers at Jasco:
http://www.jascoproducts.com/support/manual-downloads/index.asp
Type in your keyword search for 'Timers' and the manuals show.
Add a comment if you are still having a problem, I specialize in timers
11/5/2010 4:10:44 AM • Jasco GE 06685... • Answered on Nov 05, 2010
INSTRUCTIONS for digital heavy timer with ASTRO model # 457864
need instructions for model 457864
12/3/2014 11:43:18 PM • Jasco Hardware &... • Answered on Dec 03, 2014
Defiant daylight heavy duty timer instructions or
Should I hear a faint buzzing sound from the timer after it is plugged in to the socket?
3/24/2014 1:16:56 AM • Jasco Hardware &... • Answered on Mar 24, 2014
0answers
#15207 timer, Need to know
Normally, timers need to have a seperate power source for operations besides the power source it is controlling. Two posts should read "clock" for the timers power source. The other power source that is being controlled uses "line" for the incoming and "load" for the Hot water tank. Hope this helps.
9/16/2011 1:49:13 PM • Jasco Hardware &... • Answered on Sep 16, 2011
I have a Lithonia dusk to dawn flood light that's brand new there's also an on off switch. What does the on off switch control and for dusk to dawn should it be on or off?
  • When the switch is ON, the light operates in dusk-to-dawn mode. In this mode, the light automatically turns on at sunset and turns off at sunrise. When the switch is off, the light stays off.
4/18/2024 7:13:42 PM • Hardware &... • Answered on Apr 18, 2024
2answers
Grasslin QE7+ water heating timer dial problem
motor or gear failure
3/12/2024 10:39:33 AM • Hardware &... • Answered on Mar 12, 2024
Electrolux KOAAS31WX oven timer has maximum 20 minutes.
It sounds like the button contacts aren't making good contact. If you can get behind them you can spray them with electrical switch cleaner. ..
3/2/2024 6:36:01 AM • Hardware &... • Answered on Mar 02, 2024
How do I reset the ellis geyser timer to save electricity
Press P (program )on the timer and display will show then change the desired day, time and minute using the D+, H+ and M+ buttons. Press P again to set up another program and repeat the second step as above
2/26/2024 7:44:48 AM • Hardware &... • Answered on Feb 26, 2024
How do I program outdoor timer model 28486
Clear memory by pushing the reset button on the timer then reprogram using your current schedule when you want the timer to go off/on. Use the day and clock buttons for this then press enter
2/26/2024 7:35:43 AM • Hardware &... • Answered on Feb 26, 2024
Should the utiletech 24 hour manual timer make a humming noise while on?
No, the timer should not make any noise. The noise should be a result of loose connections which cause arcing, which can make a humming or buzzing sound. If you find that you still notice the sound, even when the main breaker is off then the problem is not electrical in nature.
2/26/2024 5:38:54 AM • Hardware &... • Answered on Feb 26, 2024
Jasco GE 06685 24Hour Mechanical Timer Switch White Logo
5 questions posted
Top Jasco Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Jasco Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Jasco Hardware & Accessories
Most Popular Question
lost instructions program 7 day
  • Hardware & Accessories
