20 Most Recent Woods InWall 7 Day Digital Programmable Timer (59018) Questions & Answers
http://www.ccixpress.com/cci/Marketing/Woods_US_Timer_Instructions/TM_59018K_InstrMan.pdf
Woods InWall 7... | Answered on Nov 20, 2015
Copy following link to identify timer and download manual + wiring:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Woods InWall 7... | Answered on Dec 05, 2013
If this is new installation, then Timer is wired wrong:
If timer worked before, then it has gone bad, buy anotyher timer
Copy following links to identify type of timer, single-pole, 3-way etc:
http://waterheatertimer.org/How-to-wire-timers.html
Gene
hh
Woods InWall 7... | Answered on Sep 25, 2013
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59018
Add a comment and describe timer in detail for best possible answer.
Say also if this is new timer or older timer that stopped working so we are not guessing.
Try resetting timer using reset steps shown in manual, and then reprogram.
Buy another timer.
Gene
h
Woods InWall 7... | Answered on Aug 25, 2013
1) It is safe, but not code.
The timer uses such a tiny amount of power that the installation is safe, and the line is still protected by circuit breaker.
http://waterheatertimer.org/Troubleshoot-household-electricity.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
2) In the main breaker box, the neutral wires and ground wires are bonded together and both connect to ground wire leading out to pole and down into the ground.
3) By code a ground wire cannot be used as a neutral, even though both are connected together in the main box.
This is so electrician can work on ground wires while ASSUMING they do not complete a circuit.
NO ELECTRICIAN should assume that, since the purpose of ground wires is to ground stray current.
Woods InWall 7... | Answered on Dec 30, 2012
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Woods InWall 7... | Answered on Sep 14, 2011
I don't have answer for defective timer. Buy another timer if everything below checks out:
59018 7-day timer has limited 1 year warranty, and appears to be made by Tork
Timer is for 120Volt single-pole only.
Rated for 1000 watt tungsten, 8A ballast, 1/4 HP
Push reset button with toothpick > not necessary to press-and-hold other button to accomplish reset.
After reset, 12:00 am Monday should display.
Programs are deleted. Reprogram timer.
To check, change and delete specific programming, press PROG key until selected program displays, and then set new programming >>> or press-and-hold MODE button and press PROG button again to delete selected program.
Timer has non-replaceable 30-day carryover battery and does not lose programming after power outage, and will retain programs until battery is depleted.
Review wiring:
Hot to timer black.
Neutral to timer white.
Load to timer red.
Ground to timer green.
Lights will blink if timer red and timer white are connected to load together.
Timer will not function if timer black and red wires are reversed. Display will not show.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Woods InWall 7... | Answered on Aug 08, 2011
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Woods InWall 7... | Answered on Aug 06, 2011
Woods 59018 single-pole 7-day 7-program timer, color white:
I test timers and 3-5% arrive defective, and they never work. Some stop working within 1 year, and some last quite a while.
Timers are affected by line interference and polarity issues. So wiring in home has to be correct before timer will operate as expected.
Timer has to be installed correctly with each wire correctly connected.
Press manual override button and see if lights turn on-off. This will indicate if your timer is wired correctly. If lights do not turn on-off with manual override, the open link above for wiring instructions.
To begin programming, reset timer by pushing in the round reset button with toothpick or paper clip.
12:00 am Mon should display.
If the above items are all correct, then defective timer is suspect.
If you try multiple timers, and each timer has same problem, then line interference or bad wiring is suspect, or you are buying from somebody who has a bad batch of timers.
Try wiring same timer at neighbor's house and see if it works there.
Woods InWall 7... | Answered on Jul 10, 2011
Timer is wired wrong and timer white and timer red wires are probably connected together.
Timer white wire has to be connected to white neutral wires that are twisted together and shoved to back of box. This will power the clock mechanism inside timer.
If box does not have white neutrals, then connect timer white wire to bare ground wire along with timer green wire.
Timer black wire connects to Hot wire.
Timer red wire connects to Load wire.
You might find possible solutions on following link
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help, and include brand and model number of timer, and explain exactly what steps you have done so far.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Woods InWall 7... | Answered on Apr 26, 2011
Newer thermostats and timers use small relays on their circuit boards that can be heard when they switch on and off. It is normal.
Woods InWall 7... | Answered on Apr 03, 2011
I test timers.
Some arrive defective, and some go bad quickly.
Industry standard is 1 year limited warranty.
All these timers have reset button that should restore functionality.
You posted under Woods digital programmable.
Open link to download on-line manual and read ez wiring steps.
This timer is reset by pushing reset button, without pushing any other button.
Some timers require on-off button to be pushed while pushing reset button.
I suggest turning off power to timer and see if that 'resets' timer.
Otherwise open link below and run through troubleshoot checklist, and also double check wiring.
If timer will not function correctly, then exchange for new timer.
Resourceful do-it-yourselfer can buy similar timer at Home Depot located near light fixtures and doorbells.
GE15086 -or- GE15071 with daylight savings time.
Advantage is ez exchange if problem occurs, and you give yourself extended warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Add a comment for more free help.
Woods InWall 7... | Answered on Mar 20, 2011
Hello. Yes the door hindges at the top. and unfortunately yes, too much pressure can crack/snap the plastic. This can be minimized by using a precission screwdriver as it will actually fit into the slot and effect the catch itself. a screwdriver that is larger then the slot does not push the tap that actually "grips". I've been told that installing the timer with the door already popped is a benifit. Just take it slow and steady and you should be fine.
Remember to rate this if it helps.
Thank You,
Richard
Woods InWall 7 Day Digital Programmable Timer (59018) Logo
Popular Tags
30 questions posted
Top Woods Hardware & Accessories Experts
Gene Haynes
jdthefixer
NOEL
NOEL
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Woods Hardware & Accessories
Most Popular Question
trying install woods 59018 older copper
  • Hardware & Accessories
