20 Most Recent GE 15107 24Hour Yard Stake Timer Questions & Answers
2answers
How do i set the timer for a GE emp700ul-pc, cat#15147
F= offO= on1-9= # of hours it stays on after duskD= on from dusk to dawnR= random hours is stays on after dusk each night
11/28/2023 5:11:24 PM • GE 15107 24Hour... • Answered on Nov 28, 2023
Cannot turn dial to set current time. Entire dial rotates clockwise and cannot get current time at arrow
I have the same problem, someone please help
12/3/2013 2:57:00 PM • GE 15107 24Hour... • Answered on Dec 03, 2013
How do I set the timer on the timer dial
You can get the manual on the link below. If this is not your timer please give the make and model # so I can get you the right one.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Good Luck
5/13/2011 3:25:56 AM • GE 15107 24Hour... • Answered on May 13, 2011
0answers
I need instructions on how
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15107-Manual-eng-spn.pdf
Above is link to GE 15107 manual
This is a 15amp timer that can handle up to 1440 watts
How to set timer
Rotate center dial to set current time
Line up current time with triangle on inner part of dial
The timer dial shows nighttime hours on dark part of dial, daytime hours show on light part of dial
The timer dial rotates like a clock after it's plugged in
The outside edge of timer dial has 48 segments
Lift up these segments for times you want timer OFF
Segments down for timer ON
5c24d6c.jpgSegments up, timer OFF. Segments down, timer ON.
Segments in photo are on the GE 15207 timer
10/22/2010 10:12:59 AM • GE 15107 24Hour... • Answered on Oct 22, 2010
GE washer 175D2750G335 won't turn on
If your GE washer's timer display turns on but the cycle doesn't start when you press the start button, there could be a few potential reasons for this issue. Here's a troubleshooting guide to help you diagnose and potentially fix the problem:
  1. Check Power Supply: Make sure the washer is properly plugged into a working electrical outlet. If the outlet is functioning correctly, you should see the display light up.
  2. Door/Lid Lock: Most modern washing machines have a safety mechanism that prevents the cycle from starting if the door or lid is not properly closed and locked. Ensure that the door or lid is closed securely and that the lock mechanism is engaging properly.
  3. Pause/Cancel Button: Some washers have a "Pause" or "Cancel" button that might need to be pressed before starting a new cycle. Check if your washer has this feature and if it's engaged.
  4. Child Lock: Certain models have a child lock feature that can prevent the washer from starting. Check your washer's manual to see if this is the case and learn how to disable it.
  5. Error Codes: Look for any error codes or messages displayed on the screen. These codes can provide valuable information about what might be causing the issue.
  6. Reset the Washer: Try resetting the washer by unplugging it from the power source for a few minutes, then plugging it back in. This can sometimes clear minor electronic glitches.
  7. Water Supply: Ensure that the water supply to the washer is turned on and the water hoses are not kinked or blocked.
  8. Drainage: If the washer believes there is still water in the tub from a previous cycle, it might not start a new one. Check if the drain hose is properly connected and not clogged.
  9. Timer/Control Board: If none of the above solutions work, there might be an issue with the timer or control board. These are complex components that might require professional diagnosis and repair.
  10. Professional Help: If you're unable to diagnose or fix the issue on your own, it's recommended to contact a professional appliance repair technician. They can accurately diagnose the problem and suggest the appropriate solution.
Remember, safety is important when dealing with appliances. If you're uncomfortable with troubleshooting or repairing the washer yourself, it's best to seek professional assistance.
8/9/2023 10:41:58 AM • GE Hardware &... • Answered on Aug 09, 2023
Need color codes to timer switch for model DSKP333EC5WW
The color codes for the timer switch for model DSKP333EC5WW are as follows: Red - Power, White - Start, Black - Common, and Blue - Ground. The red wire needs to be connected to the power terminal, the white wire needs to be connected to the start terminal, the black wire needs to be connected to the common terminal, and the blue wire needs to be connected to the ground terminal on the new timer switch GE part # WE04X23897.
1/4/2023 1:21:03 PM • GE Hardware &... • Answered on Jan 04, 2023
Where can I purchase timer wheel for GE 15164
You can purchase a timer wheel for a GE 15164 timer at a number of different places, including:
  1. Home improvement stores: Many home improvement stores, such as Home Depot and Lowe's, carry a wide range of timer parts and accessories, including timer wheels. You may be able to find a timer wheel for your GE 15164 timer at one of these stores.
  2. Online retailers: You can also purchase a timer wheel for your GE 15164 timer online through a retailer such as Amazon or eBay.
  3. GE Parts Store: You can also purchase a timer wheel directly from the GE Parts Store, which is the official parts and accessories store for GE appliances. To find a timer wheel for your GE 15164 timer, you will need to search for the specific part number for the timer wheel, which should be listed in your owner's manual or on the manufacturer's website.
  4. Appliance repair stores: Finally, you may be able to purchase a timer wheel for your GE 15164 timer at an appliance repair store. These stores often carry a wide range of appliance parts and accessories, including timer wheels.
It's always a good idea to check with multiple sources to find the best price and availability for the timer wheel you need.
12/30/2022 5:54:01 PM • GE Hardware &... • Answered on Dec 30, 2022
2answers
Need instruction for GE YD620
I need instructions for my yd620 G E. Hrs 2,4,6,8,
11/24/2022 4:07:20 PM • GE Hardware &... • Answered on Nov 24, 2022
Ge 15071 smart time that's been installed for years - can't manually override on/off and not coming on with timer. Bulb is good. Is there another way to override to on besides pushing the door panel?
Just replace it. They wear out, even the electronic type. https://www.ebay.com/p/1600036286 https://www.google.com/search?client=firefox-b-d&q=Ge+15071+smart+time They also have an internal battery though, which does wear out. I found this on Fixya. this is most likely your issue. The battery is build into circuit board and not replaceable. The following 2 links have resources for 15071 programmable timer: http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall http://waterheatertimer.org/Programmable.html#15071 ..
5/14/2022 11:16:07 PM • GE Hardware &... • Answered on May 14, 2022
How do I set a 4 hour cycle on a GE model YLT-i5 outdoor 3 prong timer?
It seems to be a little known model. This is the closest I can find YT-42A. Can you add a picture of yours? I have experience with one and two button electronic timers and all types of mechanical timers. https://fccid.io/2AEQYYLT-42A-3C/User-Manual/User-manual-3865177 https://www.google.com/search?q=GE+model+YLT-i5+outdoor+3+prong+timer ..
12/4/2021 11:09:49 PM • GE Hardware &... • Answered on Dec 04, 2021
I need help with a GE YLT-15 outdoor 3 outlet timer to light Christmas decorations
Request instructions from GE.
12/21/2020 3:36:04 PM • GE Hardware &... • Answered on Dec 21, 2020
2answers
Reassembling my ge timer #175d6604p053
Did u get it fix
11/10/2020 4:50:09 PM • GE Hardware &... • Answered on Nov 10, 2020
2answers
I have a GE time switch for my pool,the orange light is on showing it`s getting power from breaker, the green light is on showing timer is on but the timer does not shut off pool,green light is on.
Depending on the model you have, you may have a stop lever that needs to be readjusted. You might try resetting your system.
9/12/2020 4:50:00 AM • GE Hardware &... • Answered on Sep 12, 2020
GE 15313 In-Wall Digital Timer. The light is partially on when it should be off and when it should be on, it is fully on. Is this normal or do I need a new switch?
Not sure if it is normal (probably not) but it is certainly reason to check it is being used only with a filament lamp (not fluorescent, not CFL, not led) and the ground connection to the switch is good. If all is ok and the glowing light bothers you it will be time to buy a new switch but if it doesn't bother you and if the switch isn't heating up, there seems no urgency to replace it.
6/21/2020 5:20:05 PM • GE Hardware &... • Answered on Jun 21, 2020
How can I setting my GE Timer 686532?
That's not identifiable number for timers of any brand. GE timer manuals appear following link: http://waterheatertimer.org/GE-timers-and-manuals.html
11/3/2019 10:22:48 PM • GE Hardware &... • Answered on Nov 03, 2019
I need replacement on off trippers for my GE 15350 mechanical pool timer. Where can I purchase?
electricial supply store --online search
6/2/2019 8:54:49 PM • GE Hardware &... • Answered on Jun 02, 2019
GE 15107 24Hour Yard Stake Timer Logo
12 questions posted
Top GE Hardware & Accessories Experts
Paul Bade
Ngoro
john h
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • GE Hardware & Accessories
Most Popular Question
need instructions
  • Hardware & Accessories
