20 Most Recent Sterling Tubshower Faucet Questions & Answers
One thing you might check is to make sure the spring is installed properly. The small end of the cone should be facing out.Thank you.
Sterling... | Answered on May 19, 2011
Try this link.
https://s16962.pcdn.co/wp-content/uploads/2017/02/17469_Install.pdf
Sterling... | Answered on Apr 07, 2019
Your fixture body may be corroded beyond repair. Since you've replaced all the rebuildable parts, I'd suggest you get a plumber to check it but expect that you'll need to replace the faucet. Get a modern "cartridge" (Delta, Moen or Kohler) fixture that can be easily repaired indefinitely.
Sterling... | Answered on Oct 28, 2017
Partial blockage vent clog / damage
Plumbing | Answered Yesterday
Generally no, a faucet has either has a compression washer or o-ring. The can become scored or cracked and therefore should be replaced.
Plumbing | Answered on Feb 20, 2021
figure out who made it and check their website for parts. they all have pictures to identify what you have
Plumbing | Answered on Feb 04, 2021
I would begin by going up on the roof to see what the situation is because you are going to have to remove the stove pipe and repair the roof to assure no leaks. Usually the only thing holding the pipe is roof cement through a rubber boot. Use a razor blade knife to cut through the tar, then remove the boot by pulling the roofing nails that hold it in place. After that, patch the roof and reshingle. If this is more than you care to do yourself you will have to hire it done. good luck
Plumbing | Answered on Jan 29, 2021
Hex set set screw bottom side of handle hub. I see no adjustments... likely you will need to replace the cartridge.
http://structuredflowfaucets.com/wp-content/uploads/2016/12/912090B.pdf
Plumbing | Answered on Jan 25, 2021
Run diagnostics.
Settings > System > Diagnostics
If no problem found, try System Reset.
Settings > System > Reset > Reset System > Cancel or Reset System
IMPORTANT!Resetting the system will return your interface to the original factory default settings. This will also delete any custom configurations or settings.
replace the leaking parts
The market is full of brands making these faucets but how to decide which one is the best suited to your needs. Below mentioned are few things which should be kept in mind while making a purchase of a touchless kitchen faucets.
  • Position of the motion sensor
    It is important to check where the sensor is placed on your kitchen faucet. Their position varies from brand to brand. Some of them come with the sensor installed on their spout, while others have them at the bottom or the top of the faucet. It is up to you to select the one which suits your needs. Moen touchless faucets have two sensors, and the wave sensor is placed at the top which is responsible for the activation and deactivation of water flow and the other sensor, ready sensor is placed at the bottom, which is used merely for identifying the articles in your sink.
  • Power Source
    When it comes to a power source, there are two types of touchless kitchen faucets in the market. For the ones that need a continuous power supply you have to make sure that they are installed near a power outlet in your kitchen. The other type runs on a battery and can be placed anywhere. You can choose either depending upon your kitchen needs.
  • Others
    Before buying the faucet for your kitchen make sure its length, height, etc. is appropriate for your kitchen. Also make sure whether it is easily installable or not.
Plumbing | Answered on Jan 19, 2021
so acquire the instructions from moen and get it done right
Plumbing | Answered on Jan 13, 2021
Every 2-3 weeks, someone or something clogs it.
Plumbing | Answered on Jan 09, 2021
Sterling Tubshower Faucet Logo
2 questions posted
Top Sterling Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Sterling Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Sterling Plumbing
  • Sterling Plumbing
Most Popular Question
sterling 2
  • Plumbing
