20 Most Recent
Price Pfister Bedford Three Handle TubShower Faucet with Acrylic Windsor H Questions & Answers
What is large nut assembly in tub unit?
You are probably looking at the stem.
Go to a hardware store and ask to look at an older stem. You will see what it looks like. You will get better service from Ace, Sentry, etc.
The easiest way to repair it is to get the kit with new stems and handles. It come with a wrench to fit the stems. You will need a seat wrench to remove the seats. Put pipe dope on the seat threads and get grease to grease up the stems.
If you can't get the wrench to fit into the hole in the tub wall, yoiu will have to make it bigger some how. Just don't go bigger than the size of the trim.
MAKE SURE THE FAUCET IS IN THE OPEN POSITION BEFORE REMOVING THE STEM. If you don't, you will destroy your valve in the wall and be in for a $400 to 800 repair bill and a hole in the wall.
Price Pfister...
Answered
on Jul 04, 2014
How to replace all the valves hot ,cold , diverter
If you don't really want to tear into the finished tile, you could repair this units most likely. You will have to shut off the water in the house. Remove all handles. Loosen large nut assembly and unscrew the valve stem. If you remove the valve stems you can purchase the complete assembly at a full service plumbing supply co. If the seats are not removeable, a reseating tool is inexpensive. Replacement knobs are available if they are unsightly. The replacement will require removing tile, drywall, cutting or de-soldering piping. Purchase a new valve and follow directions to install. Home depot sell Price Pfister faucets.
Price Pfister...
Answered
on Jul 11, 2010
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Price Pfister...
Answered
on May 15, 2019
I have a slow drip on my bathroom faucet. how do i
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
Price Pfister...
Answered
on Jun 14, 2017
