20 Most Recent Campbell Hausfeld Electric Pressure Washer 1800 Psi Questions & Answers
Reset switch won't work
this is usuall caused by the high pressure cut out switch not returning properly. the high pressure cut out switch is a plastic assembly on the pressure head. open it up ,lubricate or file it to increase space. then test before re-assembling it, beware of possible exposed wires and chance of comming into contact with electricity. disconnect power while working in it!
4/1/2014 7:51:56 PM • Campbell... • Answered on Apr 01, 2014
How to hook up a pressure washer by Campbell hausfeld
Hook up the water hose and plug it in I assume it is electric.
10/11/2016 7:24:20 PM • Campbell... • Answered on Oct 11, 2016
4.0 HP 2.1 GPM Model No. PW165001LE Starts fine and begins to spray for about 30 seconds.. Then water begins pouring from base of engine...
cuff kit for the pump housing a service manual but it could together sometimes expensive , look at the plungers they must be stainless ,before the dicision ,The age for a pressure washer depends mostly on the speed range mostly in two speeds in 1600 or 2800 rpm. a 2800 rpm is usually an entry level model and an age of 7 or 8 years on average. the 1600 rmp and with a brass pump is a quality product, and if its COMET Kraenzle DIBO INTER PUMP than it pays,, in your case http://www.partselect.com/Models/PW165001LE/#Parts
8/5/2015 3:32:24 PM • Campbell... • Answered on Aug 05, 2015
Campbell Hausfeld 2200 psi pressure washer doesn't build up pressure
2 possibilities. It is not getting enough water from the hose or your pressure regulator is bad. Does it sound like the engine is developing full RPM? Could be and engine problem if not coming up to full speed.
5/4/2015 8:43:51 PM • Campbell... • Answered on May 04, 2015
2answers
Why does it leak form the gun
Because the seals are shot and need to be replaced.
3/22/2015 2:49:08 AM • Campbell... • Answered on Mar 22, 2015
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
1/31/2015 6:18:43 PM • Campbell... • Answered on Jan 31, 2015
Water wizard how to change oil
There is a small Black threaded cap located on the Bottom portion of the motor. This is your drain plug. There should be 2, one is a little higher which is your Oil fill plug (usually Yellow or Red), the lower one which is on the opposite side should be your drain plug. Could also be a square head screw located at the bottom of the motor that you remove to drain the oil. Hope this helps.
8/11/2014 1:16:25 PM • Campbell... • Answered on Aug 11, 2014
I have a gas powered 2200 PSI Cambell Hausfeld pressure washer when i try use it the pressure pulses up an down the complete time you hold the trigger down an ideal what i should look for Thinks
Quite often this can be caused by low water supply. Check the filter that the supply hose plugs in to and make sure your water supply has plenty of pressure and volume. There will be a water volume rating in litres per min (lt/min) or (gal/hr) depending on what part of the world you live in. You need to have at least that amount plus half again feeding the machine under a reasonable pressure 6ft/lb Gravity fed from a tank won't cut it. If it is vibrating and hardly working there is grit stuck under one of the valves which isn't a biggie but if you don't know how to disassemble the pump valves take it to someone who does as there are small parts like springs etc that are easily lost. It won't break the bank to get someone to repair it. Cheers. Hope this helps.
6/27/2014 2:39:58 AM • Campbell... • Answered on Jun 27, 2014
0answers
Campbell Hausfeld Electric Pressure Washer 1800 Psi Logo
Popular Tags
5 questions posted
Top Campbell Hausfeld Garden Experts
Jay Finke
Jay Finke
john h
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Campbell Hausfeld Garden
Most Popular Question
reset switch work
  • Garden
