20 Most Recent
NIB Shop Force Universal Pressure Washer Accessoriesnib Questions & Answers
I need a manual for
I have a question because I am using a gas pressure washer more long time but I want to use electric pressure washer so please tell me something about the best electric pressure washer.
http://car-gears.com/
When I turn on the
OK here's what you do: Very patiently dissasemble the housing at least enought to gain access to the valve body caps on the pressure pump unit. Don't worry about the electric motor part just the pump itself. Be careful to note the location of each screw and part you remove. They may be different lengths and you want to be able to put the thing back together again exactly the way it came apart. I mean the housing or chassis parts, that is. Now once you gain access to the pump you should see valve body caps in four or six locations on one ore more sides of the pump. They will look like bolt heads, big ones. Pick one as a starting point and unscrew it. Remove it and the spring and valve components carefully noting the order of assembly. Set these parts aside and mark which hole you removed them from. Then continue on to the rest of the valves in the same way so that you can then inspect all the pieces and compare them againstthe other valves without losing track of which parts came from which hole. Clean all the parts and lube them up with Silicone spray. Shake the can really good before you use it. Thoroughly inspect the passages in the pump body for rust, debris, corrosion or really anything that should not be in there like pieces of torn o-rings or plastic shavings from the factory. Also look for metal shavings from the machining process that may not have been rinsed out of the pump body during manufacturing. Remember you said yourself it broke almost from the time you first used it. I can tell you that you just learned a valuable lesson. Sometimes things are not assembled properly at the factory or there has been some problem with the process that was overlooked. That means that things that are flawed will always tend to break very soon after being put into use the first time. This goes for anything mechanical even cars. So what that is telling you is that the problem should be simple and easy to correct because you are only looking for what they did wrong during assembly and you aren't concernined with looking for worn out parts. Make sure all the valve assemblies you removed are assembled in exactly the same order. If one is not the same as the rest, that's the problem. Make sure they are clean and free of grease, corrosion, debris. Spray silicone lube all over tem and all down inside the pump body and reassemble everything. It should work fine after that. OH wait! While you are at it, remove the tip from the wand and make sure there is no restriction in the tiny hole from something like a small rock getting stuck in it. That will wreak havoc on the pump and make it keep opening the pressure bypass because of over pressure. Kinda like when the pump is running but you are not spraying. The pump recirculates water to prevent over pressure. Anyway don't be afraid to blow out all passages with compressed air while you have the pump disassembled. Anyway like I said carefully reassemble everything and give it a try. hould work great. I think I'm going to go do mine, too now that I've put all this thought into it! Good luck.
Weed trimmer (2 wheeled) screeches.
All questions need full 'make model (what is is)' as first 3 words please. Very often, issues like this are a known fault and users tell the fix.
You need to track down where the screech is coming from?
Wheels
Drive Belt
Bearings
Piston rings
Or it may be battery operated?
4/24/2024 10:27:50 PM •
Garden
Answered
23 hours ago
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow:
Check the Seals and O-Rings:
Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve.
Unscrew the pump: Remove the pump to access the internal components.
Inspect the seals and O-rings:
Look for any damaged or worn-out rubber seals.
Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place.
Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease.
Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube.
Reassemble the pump: Put the plunger back into the tube and lock it with the handle.
Test the sprayer: Pump it up and check if it maintains pressure without leaking.
Inspect the Handle and Hose:
Handle connection: Ensure the handle is securely attached to the cylinder.
Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose.
Check the Nozzle and Wand:
Nozzle adjustment: Adjust the nozzle to the desired spray pattern.
Wand inspection: Examine the spray wand for clogs or obstructions.
Lubricate O-Rings and Seals:
Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation.
Test the Sprayer:
Fill the cylinder to the desired level (avoid exceeding the maximum fill mark).
Screw down the pump firmly to create an airtight seal.
Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM •
Garden
Answered
2 days ago
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
on Apr 20, 2024
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM •
Garden
Answered
on Apr 17, 2024
Scotts lawn mower 21995x8b manual
I'm guessing you have fixed this or given up after 13.5 years, but here is my suggestion for the next person who has this trouble. If you ran it out of fuel and left it over the winter, it could have a drop of fuel that hardened and plugged one of the fuel ports in the carburetor. I have had this happen and needed to remove the fuel bowl and poke the dried film with a pin. Put it back together and it started right up.
3/31/2024 1:19:11 AM •
Garden
Answered
on Mar 31, 2024
