20 Most Recent
Stanley 1600PSI Pressure Washer w 20ft Hose Accessories Questions & Answers
Leakage from the garden hose connection along with
The female hos bib connection should have a typical hose washer inside.Often you can't tighten the nut tight enough without this washer, to keep it from leaking both from the hose, and the rest fo the fitting into the washer.
Stanley 10-801 utility knife. How
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
