20 Most Recent Craftsman sears 18" Chain Saw Chain ( Model 35084 ) Questions & Answers
2answers
Chainsaw
Most likely the reason for the failure to start when hot is worn piston rings. Do you have small amounts of oil coming out the exhaust? That's a good sign of worn rings. If qualified, replace your rings and bore out your piston sleeve. You'll be running like new and no more having to wait until it cools to finish the job.
3/25/2015 11:34:48 PM • Craftsman sears ... • Answered on Mar 25, 2015
How do I install the throttle valve and butterfly on a craftsman chainsaw
Always take pictures or make notes to help out like a road map if you left fuel li new attached to the other it will then be noticed
2/12/2015 5:26:51 AM • Craftsman sears ... • Answered on Feb 12, 2015
3answers
The chain keeps coming lose and falls off
Make sure chain tension on the bar is correct and then the 2 nuts holding the bar is correct, Youtube has alot of videos on how to set chain tension as well as the Oregon website
1/6/2015 6:56:55 PM • Craftsman sears ... • Answered on Jan 06, 2015
Settings for carb. on a 42 cc chain saw
Initial settings are one full turn CCW on both low and high side adjustments.
11/27/2014 11:28:26 PM • Craftsman sears ... • Answered on Nov 27, 2014
What is the correct file diameter for the chain on Sears chainsaw model 358.360380?
Go to a good hardware store. I believe that all chains use the same size file. You can also get a guage there also.
11/27/2014 8:32:19 AM • Craftsman sears ... • Answered on Nov 27, 2014
Craftsman 16"what is the starting carb adj
Gently turn both carb screws in all the way. Then turn each out one turn. The fast screw is marked with an H and the slow is marked with an L.
9/15/2014 4:14:29 PM • Craftsman sears ... • Answered on Sep 15, 2014
Sears 18 42cc chain saw blade keeps coming lose
I have found that the number one reason for a loose chain is from stretching, and that comes from heat or clearing small brush. Heat being that it is not oiling properly and wears quicker, and the small brush answer (cutting lots of 1/2 in Buckthorn) tends to jerk the chain and manually stretches rather than a steady cut in a log which tends to be smoother.With that said, yours might be something else. If I can ask a few question... When the saw was purchased, did you install the bar and chain? Second your level of experience - and is this your first saw. What I need to rule out is that the bar could be on wrong. This saw was more than likely built by Poulan and it should have 2 nuts holding the bar. Does the bar loosen up? If the answer is no you might have a bar that is miss matched to the chain. What that means is that the chains "drivers", the tooth that is down in the bar could be a .050 and the bar could be a .063, hence the chain wobbles more that it should and might be more prone to jumping off. Solution: Replace bar and chain and make sure they are a matched, lastly, always cut with a sharp chain. Good luck,kj
8/27/2014 3:30:29 AM • Craftsman sears ... • Answered on Aug 27, 2014
Spark plug gap settings chart
.025"
7/28/2014 10:27:06 AM • Craftsman sears ... • Answered on Jul 28, 2014
Describe your sears 18"
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
4/24/2014 11:33:59 PM • Craftsman sears ... • Answered on Apr 24, 2014
What does a spark plug gap at
hi, your spark plug gap should be the thickness of a hacksaw blade. use a hacksaw blade. sheers
4/24/2014 1:43:30 PM • Craftsman sears ... • Answered on Apr 24, 2014
2answers
Torque specs
LOOKING FOR KIA PICANTO BIG ENDS BOLT TORQUE
4/24/2014 1:39:56 PM • Craftsman sears ... • Answered on Apr 24, 2014
Headbolt tension
Hi Belinda, I am not sure what you are asking for when you say headbolt. If you mean cylinder bolt, jug bolt or head bolt then approximately 125 inch pounds.. not foot pounds!!! This image I found for a Poulan chainsaw site, Poulan makes most of Craftsman saws. If you match the size you should find your torque setting. jeromekj a393cbab-214e-4579-8b3f-20209e4c81a3.jpg
4/22/2014 8:28:43 PM • Craftsman sears ... • Answered on Apr 22, 2014
No spark or fire
i would suspect coil to flywheel distance too great
3/8/2014 9:10:11 AM • Craftsman sears ... • Answered on Mar 08, 2014
Craftsman sears  18" Chain Saw Chain ( Model 35084 ) Logo
90 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
chainsaw
  • Garden
